Results 1 to 15 of 15
Thread: K swap info? 96 Teg 4dr
    Ohio asshole.
    Default K swap info? 96 Teg 4dr
    I'm very knowledgable, and can do B swaps with my eyes closed.
    However, I've got a 96 Integra, LS.
    I'm really considering a K swap, but I have NO idea where to begin.
    I live in BFE Pennsylvania, and I want to do something different up here, as apposed to all the riced out piles that run around.
    What motor, and trans, as well as what it comes in stock, would be best? Easiest as far as swap, with a poss. of a mild NA build, or low boost (10-12 psi) later.
    What ECU?
    How much of a pain in the ace is the wiring? I'm decent at wiring, though, I am definetely a little leary on the K swap wiring. I got to check out an EK in cleveland with a K swap, guy said there really wasn't much wiring at all.
    What I know I need are, Hasport mounts (i'll probably build my own), hasport axles (if i want them to fit right)
    Also, where can I get the components for the shifter assy.
    Again with trying to be different up here. I have plans on a jdm bumper, lights hood and fenders, eventually. WIll that effect anything with this swap?
    Ohio asshole.
    So, what did you type in google, b/c all I found was didly squat! Hence my post here lol.
    Can't rep ya currently, or I would.
    DC5-R
    Gwinett
    search man.
    for the most part the k20a2 is a good candidate and there is alot of aftermarket support for this motor. The k20z1 is a bit stronger but will require you to do a little modifying to the speed sensor. The k20a is BY FAR the best one but the most expensive one. Check out hybrid racing, R-Crew, hasport, chasebays, etc. This should get you started.
    call hybrid racing, they got nearly all the bits and peices you need to do a k swap.. minus the actual swap
    Ohio asshole.
    Alright, i'll have to do some searching. My b18 is smoking a bit. Could be just valve seals, or could be rings. It's tough to say with out tearing it down.
    If i'm going to fix it, I'm going to do a completely Over haul. Which, I would have to do anyways if I plan on boosting. So, why not run a low mileage K, and throw 10psi at it.
    Cost to cost, plus the uniqueness (up here), and the power changes, I see the swap worth it.
    Quote Originally Posted by jmmx258
    i did k20 swap, k20 eg, k20 ek, k20 dc
    Ohio asshole.
    New plan, however I have some questions, as to whether this will work.
    I found an 07 Civic Si crushed from the rear. Junk yard will sell it, w/out a title for 1500 (which, I am buying it)
    Now, Onto the questions. I want to run the Guages, etc from the civic in my teg.
    My new plan, now, is to buy this car. What I want to do, is pull the complete head to tail wiring, ECU, everything, and just slap it all in my car. I know, its a lot of work, but, winter is right around the corner, and the integra is getting put away anyways.
    Now, I've read about immobilizers, will my plan work? doing that. I mean, taking EVERYTHING out. Any other brain boxes, etc.
    Also, do the civic still come with the coded key? Whoever wrecked the car, for some reason, kept the keys. If the junk yard won't even let me see the title (i didnt find anything in the car showing me the crashing owner), how can I go about getting a key for said car? Or, can I have the honda Dealer check the ECU and order a key?
    I also plan on making all the suspension and stuff work on the integra as well.
    The front of the car is basically perfect, so i'll be selling hood, bumper, and anything else I dont use. I'm in PA but when I'm done, i'll make a FS thread, if anybody is willing to come take these things off my hands.
    rolla rollin
    middle GA
    there was a k20 4dr integra in HCImag! it was the august 08 issue! check it out it will give you some inspiration
    Ohio asshole.
    Lol the inspiration is there. I only went to check out the motor. They wanted 1200 for the motor, trans, wiring, and ecu, or I could drag the whole car out for 1500 lol.
    Hence the reason, i want to know if my plan will work. I'd love to have all the new SI bells and whistles, as well as the power plant lo.
    Plus, If i buy that magazine, i might not have enough money left to pay tax on the car lmao!
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    i wouldnt bother trying to utilize the gauges etc. because it will be a headache. go to www.hybrid-racing.com they have EVERYTHING needed to make the swap work. you WILL need a VSS converter and a 02-04 RSX ECU with the immobilizer bypass, OR k-pro. go to that webiste and start checking things out, because they have done plenty of k-swaps. Good luck!
    Who knows?
    Ohio asshole.
    Quote Originally Posted by Identity_Crisis
    I don't think that I like you...lol. Nah, I really expected it to be a headache. I just really like the Civic Guages. I'll definitely be using the front seats, and I'm sure some other things.
    I've checked out hybrid a couple of times. Every time I do, I drool a little lol.
    rolla rollin
    middle GA
    lol i never said buy it just check out the build! i was amazed at what they did to it! went from a dd grocerey getter to a rhd jdm front 4dr! but gl with the build it should be interesting
    Ohio asshole.
    I couldn't find the build. lol. I keep lookin at Hybrid. Its making me want to do this build like...tomorrow haha. However...at the same time, its turning me away a little bit. Not sure If i want to take on this job anytime soon now. Might just wait until I pick up a new car to drive, JUST in case hah.
    rolla rollin
    middle GA
    oh if this is also your dd then yeah you should also have a back up car because this build will take you some time!
Tags for this Thread
