Results 1 to 33 of 33
Thread: TUNING for a 96 lt1
    rockem sohcem robot
    Default TUNING for a 96 lt1
    Ive got a 1996 firebird 5.7 6 speed with a lil cam headers exhaust MAF and a AIR system/ Cat converter removal and its a lil on the weak side and desiels when turning it off.
    Im positive it needs tuned. who and where guys/girls?
    "TheCrew"
    Crew member #3!
    just because I came in late I am leaving one two open haha
    Stang Mod slostang's Avatar
    Southside
    ive herd good things about atlanta chassis dyno in covington.
    Quote Originally Posted by masonhenson
    If you want to play with it yourself, just get the HPtuners.
    My dad said he remembers one of the cooling fans being hard wired (not going through a relay) and that's the reason it's dieseling... just locate the wire and run it back like factory. Worst case scenario, it's just a bad fan relay
    As far as it being weak, BEFORE the full tune up that lsvtec20 did, it stayed dead even with a LS1 SS camaro from like a 30 or 40 roll
    rockem sohcem robot
    well then somethings wrong because last night I got chewed up and spit out by my cousins stock 99 z28 from a 30 roll.. and i can drive so its not a driver error.. we even switched cars and the ls1 whooped ass.. plus theres no check engine light on but its throwing six codes
    1.MAF
    2.random multiple missfire
    3.emission control system malfunction
    4.same
    5.same
    6.same
    and where the heck is that wire at? i just looked and see nada.. i must be blind. or it could be the fact that they fit a 5.7 in the space a 2.0 shouldnt fit haha
    "TheCrew"
    Crew member #3!
    1.MAF
    4.same
    5.same
    6.same
    I know the MAF, EGR, plus, and opti were replaced (or so he told me when we met up to look at wheels. he's always been honest with me, and frankly, no reason to lie as I wasn't looking to buy the car) so maybe it just needs to be cleared? If it's misfiring, it might just be the cap and plug wires. I'm not sure. But like I said, it stayed even with my buddy's car, that has ran a 13.41 spinning, from like 35-75 or so...
    rockem sohcem robot
    where do i get hp tuners?
    "TheCrew"
    Crew member #3!
    rockem sohcem robot
    yeah i cleared them last night before i went home n this morning the emission control system failures were back on but not the MAF or missfire.. i think the MAF was sucking too much air because the airbox was not tightened on to the front of it.
    "TheCrew"
    Crew member #3!
    georgia
    i dont think a tune will help you with CEL's you just got a car thats been rode hard as hell before you. i would take it to a good shop and have them go through it and make sure its right.
    i had a 94 formula with a lt1 great car if i were you i would put a cat on it or a high flow one cause honestly there is really no gain from removing it on those cars just more headache than anything else.
    also if your maf acts up again try taking it off and gently wiping off the sensor in the middle i had a k&n on mine and some of the oil got on it and threw it off big time it bogged and ran like crap.
    and make sure who ever replaced the opti spark knew how to do it if any moisture gets in there it will screw up. i would also check for wires laying on the exaust.but get a good tech to give it a top to bottom inspection those are great cars i just hate the opti spark set up.
    yes i am....
    rockem sohcem robot
    yeah. who put a dizzy there? crap chev haha.. atleast when ford puts one up front its on the top
    "TheCrew"
    Crew member #3!
    Where Am I
    Usually I know on older cars, the dieseling ur talking about when u turn it off, is because the timing is to advanced, I'd check it to make sure....
    PS: Are u the one who got the black one?
    Woodstock
    The LS1 will out run the LT1 with the mods u listed, on top end anyways......you need a bigger cam and a set of heads if you wanna make power. The LT1 makes awesome TQ and makes it early, but the HP drops off too soon, you just need more mods.
    here ya go, they charge flat rate tuning and use LT1 edit.
    http://atlpf.com/
    rockem sohcem robot
    thanks guys and yes i got the black one.
    "TheCrew"
    Crew member #3!
    HPT does not support LT1's unfortunately. Your problem does sound more spark/timing/ECU related, def check the opti and go from there. My friends car was doing something similar and it ended up being a clogged CAT fwiw. I have a MAF from my 01 if you need a new one, I'd imagine it might be bigger and you'd need a retune. I also think I have an old MAF-T laying around somewhere...
    rockem sohcem robot
    can you use an ls1 MAF on an lt1? i have the Granelli (sp?)
    and i found out why its desieling, the fans are hard wired and it continues power to the ignition. that will be fixed soon. but im still looking for a tune
    "TheCrew"
    Crew member #3!
    Woodstock
    http://importatlanta.com/forums/showthread.php?t=217847
    Check out the mods I had, those will get you lower to mid 300's.
    If you change the opti. only use a GM unit, and its a good idea to do the water pump also.
    Might help too www.z28.com
    Im pretty sure they are interchangeable. How big is the granetelli? Thats good you found it.
    rockem sohcem robot
    im not sure how big the granetelli is.. too big prolly.. car runs VERY rich.. any way to somewhhat home tune it? all the prices i have found are 500 ish.. lil out of my budget.. a lot actually
    "TheCrew"
    Crew member #3!
    http://cgi.ebay.com/ebaymotors/LS1-L...Q5fAccessories
    You can probably sell the Granatelli for that much.
    rockem sohcem robot
    how does yours run with the granetelli? is it really necessary for what i have?
    "TheCrew"
    Crew member #3!
    I'm getting around 25mpg @ 80-85mph
    I actually was running faster at the track with the granatelli...
    rockem sohcem robot
    effff.. im getting 13 mpg mostly at like 60 mph
    "TheCrew"
    Crew member #3!
    georgia
    1.MAF
    4.same
    5.same
    6.same
    when they pulled the cat did they do the o2 delete thing check the link i think having no cat is hurting your perfomance alot.
    http://fasttoys.net/shop/product_inf...roducts_id=375
    i left my exhaust stock except a flowmaster and it ran great then i added a k&n and a 100shot for giggles and not one problem.
    yes i am....
    Woodstock
    From what I understand, the stock MAF and stock Intake manifold are good for 400ish HP. I didn't have a cat on mine and had no problems. I put down 250 to the wheels at mainstream with just headers, intake and flowmaster (catless). Thats about average for a bolt on LT1, was looking for 75ish HP from the other mods.
    rockem sohcem robot
    anyone willing to trade a stock MAF and some cash for tires for my granetelli? i also wanna trade my wheels too.. 17x9.5 boyd cottington 5 stars.. i need to get this think looking right and running right.. running right first
    "TheCrew"
    Crew member #3!
    Oct 2003
    You still work at the autozone/advance on 78? I could possibly stop by take a look at it when its not raining. You got the same exact car...96 formula firebird
    rockem sohcem robot
    Up thAt's me. I'd appreciate it
    "TheCrew"
    Crew member #3!
    MAF-T's are under $200 new and are the cheapest easiest way to tune it yourself. They are limited though as they only increase/decrease by percentages and really are just tricking the PCM. LMK if you want to try mine out, its been sitting in my garage for 3 years. It sounds like your issue now is the cam + non-calibrated maf, as in you fixed all the codes? Have you tried Vengeance? Is your car an A4 or M6? 13mpg is bad but in an A4 in the city you'll only get about 15-17 with those mods. I usually get 16 city and 23-24hwy, M6 with 400+hp.
    rockem sohcem robot
    how do i know if its an a4 or m6? lmk please?
    "TheCrew"
    Crew member #3!
    Quote Originally Posted by masonhenson View Post
    A4= automatic 4 speed
    M6= manual 6 speed
    ^^^what he said. Catnip, I want your wheels!
    rockem sohcem robot
    eff... well mines a m6 car.. and sucks on mileage
    "TheCrew"
    Crew member #3!
    Yea, you should be getting alot better than 13. Call up some local places with dyno's that can tune it and just see what they'll charge. Vengeance is in Atlanta and Ron has been tuning and messing with GM vehicles for a long time. As long as everything is functioning right it shouldnt take someone like him more than 2-3 hours to tune it. Of course it'll cost the same as buying LT1 edit and doing it yourself.
    rockem sohcem robot
    yeah ive found one place thatll street tune for around 300.. may be the way to go
    "TheCrew"
    Crew member #3!
