Results 1 to 14 of 14
Thread: 92 cx hatch headers
    kangarooster meadows
    Default 92 cx hatch headers
    Basically I just want to know if d16 headers are compatible, when I look up headers it will mention every model but the CX and I don't want to waste my time getting something that doesn't fit. Mine is stock with the cat attached to it basically, and then theres another cat added on after it. They're both gutted and it sounds like shit so I'm going to redo the whole system with no cat.
    Quote Originally Posted by alpine_aw11
    Maybe you should try looking for a header instead.
    It's called grammar son, in that application it's ok to say headers. It's plural. Thanks for the help.
    Norcross
    haha reps for the ownage. i knew someone was going to come in and say that stupid shit
    All Motor BlackDubs's Avatar
    Atlanta,GA
    ^ What he said.
    It gets pretty annoying when people reply back with dumb remarks, rather than trying help out with an answer.
    But to answer your question. Most 92-00 D series header are compatible.
    If there is a difference. It will most likely be the bracket on the bottom, not bolting up. But it will still work, with minimal to none modification needed.
    goodluck
    Atlanta,GA
    Heres a picture of a DC header that I found on here fs (by EJ1soSlo) , its to show you how D series are compatible. It says that it will fit 92-95 Civics/96-00 Civics/92-97 Del Sol. So you should be good with any header you choose.
    The bracket on the bottom isn't an issue, the whole stock system will be gone so as long as the HEADER bolts up to the head it will be worked out. And on that box it doesn't say cx, that's what I've run into with every one I looked at. Fuck it though I'll try one out. Thanks guys.
    IIRC doesnt the CX have the cat in the header up top, or was that only the EKs?
    Quote Originally Posted by Vteckidd
    Yes it does.
    edit-in case you didn't catch it, I'm not looking for an OEM replacement style header. The test pipe will be fitted about the same place it would be on a non-cx model.
    Where Am I
    Yep it will fit just fine, I did the same thing on my 96 and 97 DX's.... U really should wait though before putting it on, cause it will bolt up to ur factory cx exhaust but there is such a size difference that u won't be able to run a header gasket.... So before u do it, buy the test- pipe and catback exhaust, and just put it on all at once.
    Quote Originally Posted by j0nbunklah0m
    Tards taking it seriously lolol!
    The 92-95 CX, DX, and VX headers are all compatible. The CX is a D15B8 and the DX/LX's D15B7 header will fit on it. The same should apply for the VX's D15Z1 header.
    I'm not upset. It's just hard to tell the difference between the douchebags and the guys that joke around.
    Quote Originally Posted by Turbodude06
    That's the plan, everything goes on at once.
    Thanks everyone.
    Savannah
    be prepared to buy a resonator or you will have that horrible honda drone sound..
