Results 1 to 17 of 17
Thread: oil leak after replacing seals?
    One Curve At A Time
    Default oil leak after replacing seals?
    Just replaced crank seal, both cam seals, water pump, thermostat, and timing belt. Now leaking oil badly from crank seal( I think). Is there a chance that it was worn and thats why the new seal didnt work? If so do they make sleeves for it?
    97 DX Civic w/ H22 FS
    i drive slow im_hung's Avatar
    location, location
    sounds like a defective seal or it was damaged when installed
    One Curve At A Time
    seal looked fine and was oil'd before it was installed so it wasnt installed dry
    One Curve At A Time
    I sat a plate under the car and let it sit for around 3 hours. I lost probably around 20 drops or so
    Installed wrong ...replace seal again (new one_)
    One Curve At A Time
    How would it be installed wrong?
    they have a lip in the inside that if it gets cocked it will sip out oil... so yeah installed wrong I have seen this mannnnny times that is why (I) mechanic take a mirror and look all around the seal to make sure that the lip is perfect all around before (I) install the timing belt so i Know 100% sure it will not leak... Plus AUTOZONES (fel pro ) seals suck (the orange ones)
    I only use Honda OEM only!
    Most of the times if you lube the seal up it will slide in with out the lip bending...
    One Curve At A Time
    we did lube it. I drive a mazda not a honda tho :-p lolol
    Quote Originally Posted by FlipKing
    Well if you stated mazda then i would said that I threw that out there....
    And if you lubed it you still got it cocked on the lip to have it leaking again....So re- do it and stop complaining lol
    get a OEM one !
    One Curve At A Time
    blah, yeah, gotta take the damn thing out again.
    either bad install or bad out the box. im going to the bad install. its no biggy ive installed them wrong myself.
    Either bad install like they said or if its the style with the spring inside it to keep it tight you knocked it out maybe. Seen that once before.
    BMW 750iL
    One Curve At A Time
    One saturday soon the car will be going down for a while it seems. check the crank seal and all. dammit
    The crank may have a score in it. If you replace it again and it leaks then the crank may be messed up. You can inspect it when you replace it. You will have to take the crank out and have it welded up and machined if it is damaged by the seal. We have done this before for a customer.
    Quote Originally Posted by Batlground
    this being the issue is 1-10000 happening I seen this all but 2 times in my 12 years experience.its just some kid that installed the seal wrong is the problem , I wouldnt be surprise that they didnt have the right tool to install it right to began with.They used a extension with a hammer I bet.I do that to but i am good with making sure it will not leak.
    Also the chances of a new seal being bad is slightly also , Now buying a pos felpro (orange ones) I know they are a POS just like their orange valve cover gaskets/and grey ones.
    Take it apart and check and It might even be the cam seals leaking which you can take the cover off to see if they are if not then it might as well be the crank.
    Good luck OP
    One Curve At A Time
    thanks guys, from where its leaking I dont think its cam seals. My best guess is crank seal. I'll update once I get a chance to look it up
    One Curve At A Time
    well, had crank and cam seals replaced with name brand seals and replaced the VC gasket adding RTV to it, guy also cleaned up my motor(cleanest I've ever seen it). Havent leaked a drop that i've seen
