Results 1 to 21 of 21
Thread: my car keeps burning oil
    E38 740i M fininfarina's Avatar
    Default my car keeps burning oil
    I have B20VTEC, keeps burning engine oil.
    I do not know why, I let my car sitting in garage for a day if it leaks but theres no leaking.
    anyone know whats the reason keep burning oil?
    Stang Mod slostang's Avatar
    Southside
    what weight oil are you using?
    ballin on a budget hondalover00's Avatar
    ga
    how many miles you got on the motor...do a compression check
    ITs probably piston rings. In my experience on hondas the oil control rings seize into the piston and don't properly scrape the cylinder walls. This will NOT show up on a compression test since the compression rings still work properly.
    Certified Gearhead schia89's Avatar
    Oct 2008
    Most likely its the piston rings if theres no leak. Try doin a compression test.
    LOL Barefoot, we should run this section.
    lol technically we do. you, josh, and i. hondabuilder is on his way up. i think if we stopped answering question this section would be full of half ass throw parts at it answers.
    known as Charles
    We need more info on "burning oil". Does it do it more at idle or high rpms or all the time. How much oil are you burning (1qt every 500miles)? There could be a few different things that cause it. Also, is it a built motor or stock?
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Thanks for comments
    It happens few days ago
    When I reach vtec, it burns oil I guess.
    I just put 3 quarter more.
    Now it looks no less. I will check again,
    ^^this guy loves you jdm-civic's Avatar
    the sky
    mines does the same thing but i burn a like a quart a week, but i lowered my fuel pressure and now its like a quart every other week.i think the excess fuel was washing the oil off the walls causing it to burn
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Quote Originally Posted by jdm-civic
    What air fuel is your car running at now and what air fuel was it running at?
    barrow county
    couldnt it be bad head gasket also?
    Quote Originally Posted by blue_gt
    sure, it could be.
    What are the leakdown numbers and if there is a problem with the leakdown where is it leaking to?
    sounds like pistons rings to me.
    /Oo ___A___ oO\
    |=_/_______\_=|
    L'ville
    i agree with the piston ring theory.... common thing as well
    Atl
    credibility and reputation
    dc5
    ATL, GA
    are you smoking alot at idle?
    barrow county
    Quote Originally Posted by Axix23
    x2
    do a leakdown test already.
    Quote Originally Posted by fininfarina
    Thanks for comments
    Most likely your Oil Control rings. Oil Consumption rarely comes from a headgasket, and its almost impossible to blow a honda headgasket on a stock motor.
    To consume that much oil, most likely your rings are shot. COmpression test will only tell you if the top ring is sealing, and if you have bad oil control rings, your numbers will be "fine" as there is oil in the cylinder.
