Results 1 to 40 of 47
Thread: What combo to make 12:0:1 in an Ls
    Default What combo to make 12:0:1 in an Ls
    Using honda parts.
    Stang Mod slostang's Avatar
    Southside
    you can around 11.5:1 with b16's. CTR's are right at 12.25:1 IIRC.
    Quote Originally Posted by slovic
    Find out for sure and get back to me. Comp calulator says ls crank with gsr rods and pr3 pistons = 12:6:1. I don't like the gsr rods in a ls block thing tho.
    Southside
    CTR's are a little over 12.8:1 im checking on the b16's...
    Southside
    yeah its about 11.5:1 with b16's.
    I wanna build an ls with at least 12.0. 12:5 is max. Time to make the 4 door move out.
    Southern Speed
    Macon
    81.5mm ls with PR3's and a 1 layer headgasket will yield 12.04:1
    Out the game again!!
    southside of the border
    if your going with stock bore get b16 pistons 1layer hg and mill the head .010 that will put you around 12.2:1
    Soon!!
    Southside Ridin HATCH
    Yea and i Have some 81.5 PR3 (b16) pistons in the FOR SALE thread!
    81.5 would be 0.20 overbore right?
    ^^yea
    Soon!!
    my fav. dsmer going behind my back i see. lol. i quess u are ready for some reliable power.
    new project every week.
    Certified Gearhead schia89's Avatar
    Oct 2008
    Quote Originally Posted by y-49
    Whatever is slow will be reliable. This is why hondas never break down lol.
    Southern Speed
    Macon
    Quote Originally Posted by schia89
    Failed to see the humor
    Northwest Georgia
    Quote Originally Posted by 1badgvr4
    cant put ls crank with gsr rods anyways.
    Quote Originally Posted by DarKStaR
    Calm down man this is an on going thing between me and him. DSM vs Honda. Forgot to sign on my username.
    Quote Originally Posted by SPOOLIN
    Which I found out. Im a honda newb.
    Columbus
    just get the jdm b16b pistons, PCT....they will give you a 13.1 compression with a 3 layer headgasket.......
    Made in BRASIL junior_tm's Avatar
    Brasil
    just wondering what is PCT???
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    Quote Originally Posted by 99jdmLs
    I've been hearing those are not very good pistons to use. Something about being prone to detonation.
    PCT= civic type R pistons
    13.1 is fucking NUTS!!
    Quote Originally Posted by Black4DrEK
    If he is right then im down. Hell someone needs to try it
    Brasil
    thanks
    ToTaLMaDNe$$
    Columbus
    there were some .25 over pct pistons being sold in the for sale thread few days ago, came with OEM rings to. 175 bucks.... BNIB (a deal)
    you can buy them for 169 shipped off some sites and oem rings are around 120...
    http://www.zealautowerks.com/bseries.html
    this is the calculator that i used, change it between p30 and the pct pistons. it goes from 11.6 to 13.1 perdy nasty!
    3 different types of b16 pistons:
    (all calculations are b18/b20 with a oem 3 layer head gasket)
    p3-usdm b16 11.39:1 comp
    p30-jdm b16a 11.61:1 comp
    pct-jdm b16b 13.14:1 comp
    if you want to go ls/vtec with a gsr head kiss pump gas goodbye- 14.31:1
    yea whatever you do my friend CHOOSE wisely!!
    13.1 sounds about right. The goal is to beat lsv's. Ill update the thread when I get off my ass and do something.
    Macon
    B Series Compression Ratio's for different setups
    that should answer all your questions
    Land Rover LR3 HSE
    Thats all with a vtec head.
    Macon
    I don't know where you are getting those numbers. By my calculations, using PCT pistons in an otherwise stock B18A/B will net you around 11.55:1.
    PR3- 10.92:1
    P30- 11.16:1
    There's no way it's making 13:1 using a LS head. Those heads have larger combustion chambers than VTEC heads. Larger combustion chamber = lower compression ratio. Maybe you didn't use the correct piston to deck height.
    Even with a B18C5 block/head and PCT pistons you are only right at 12.0:1 using a stock head gasket.
    1badgvr4, are you going to be using stock sized or 0.25mm oversized pistons?
    stock sized PCT pistons are good for 11.55:1.
    0.25 over PCT pistons are good for 11.61:1.
    The only way I know of to get 13.0:1 using stock honda parts is using a B18A/B block, GSR head, .25 over PCT pistons, and a single layer head gasket, which is good for around 13.1:1.
    Most of those online calculators do not take into account the piston to deck height, and differences between head gasket types. Also, most give the wrong thickness for oem honda head gaskets.
    Land Rover LR3 HSE
    LS Resurrection
    Fulton County, Union City
    all motor ls? theres a vid on youtube, and a thread on honda-tech
    IS300 NEMO's Avatar
    We Fuckin...
    damn you trying to come for me.
    but why not just go LSV?
    Superdan Racing DAslowman's Avatar
    Vada, Ga
    The names "Skeezy1" Samhonda95's Avatar
    South Ga. (Pelham)
    i love tha pct pistons!!!!!!!!
    i've built 3 motors with them. 1 ls/vtec 1 b16 and 1 all ls and they run great!
    tha b16 with ctr cams itr intake manni and itr tb went 8.50's in the 1/8th miles with a half ass street tune
    just be sure to upgrade ur rod bolts with arp bolts.
    LS Resurrection
    Brian Crower 403 Cam's, P30 (because they fit on the stock ls rods without any mods), LS ARP Rod Bolts (to rev higher than 7k RPM), Port and Polish the head, new Valvespring, Retainers, Valves, Intake Manifold, Short Ram or Cold Air Intake, and a good tune
    Certified Gearhead trista's Avatar
    Springfield PA
    i have it.
    Middle, Ga
    Quote Originally Posted by trista
    i have it.
    You mean, PT has it.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Southside of The Jungle
    You just dont know how nuts it really is.
    Quote Originally Posted by NEMO
    Not really. How about to come get some of the other car
    PCT= b16b ctr pistons
    /Oo ___A___ oO\
    |=_/_______\_=|
    Light Tuned
    dean u need to check the pct height im sure that they will hit the ls head and im sure that the rods gotta be trimmed to fit the pct anyways so i say b16's in a ls shot peen the rods and be happy with the 11.... compression p30's are cheap anyways
