Thread: obd0 to obd1 ?????????
    you dont need to know
    Default obd0 to obd1 ?????????
    just wonderin if i buy a jumper harness from obdo-obd1 . do i re wire my dizzy and use obd1 or what , what all do i have to use and not use. any help lmk
    f*ck off
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    if its like the 0bd1-obd2 conversion harness that goes between the plugs and ecu then it should take care of everything.
    West palm beach
    you need a obd1 dizzy,and ecu. I would also go with obd1 injectors, but you don't have to.
    West palm beach
    hustler ksniperfox's Avatar
    lawrenceville
    from someone whos actually converted a obd0 car with a obd1 motor, you will need:
    the conversion harness-about $100
    obd1 ecu-about $100
    obd1 dizzy for your motor-about $100
    obd1 4 wire oxygen sensor-about $100
    then you will need to wire it all up.-about 1-2 hour depending on your skills.
    check www.rywire.com
    they sell all the shit necessary.
    Tuck'd & Swap'd Thundercat's Avatar
    Valdosta
    or do a harness swawp instead but then add injectors to the list that ksniperfox made
    ~CREW LEGIT~IMPORTALLIANCE.ORG~All IN FAB~BISIMOTO
    West palm beach
    Quote Originally Posted by ksniperfox
    obd1 ecu-about $100
    you wont need the $100 4 wire o2 sensor, because Scotty will remove it from your ecu when chipped....
    also if your gonna stay turbo, now would be a good time to get some DSM 440cc injectors if your gonna keep the resistor box
    Quote Originally Posted by punkr6
    yeah i got the blue tops and thanks rodney
    f*ck off
    West palm beach
    welcome homie...
    the dist won't be exactly plug and play...you'll have to re-pin it or get an obd0-1 dist jumper too. o2 isn't necessary if the ecu is chipped and you're getting tuned.
    West palm beach
    Cobb/Cherokee County
    i got the dizzy adapter forsale! shoot me a pm
