Results 1 to 18 of 18
Thread: WTF...........
    paint booth
    Default WTF...........
    how in the hell do i get my damn distributor seal to stop leaking? i got a O ring from the parts store and it leaked more. i bought one from honda and its still leaking.......HELP>>>>>>>>>>>>>>>>>>>>>>>>>>>
    West palm beach
    are you sure its not coming from the valve cover or cam seal ?
    NO ADVERTISING
    -IA MANAGEMENT
    paint booth
    Quote Originally Posted by punkr6
    no you can see a perfect line where oil is coming from under the distributor. i put another O ring on it today so wish me luck lol.
    West palm beach
    make sure your putting some lub on the o-ring before you install it, they will tear easy...
    NO ADVERTISING
    -IA MANAGEMENT
    paint booth
    ok
    Soemtimes the shaft on your dist will wear out and get loose and leak through the dizzy.
    you are correct!
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by boostedb16
    so was your vtec solenoid 8D but that was nothing silicone cant fix..
    /Oo ___A___ oO\
    |=_/_______\_=|
    paint booth
    ok i finally got smart and took my distributor off and took it with me and matched one up and now NO LEAK...........
    BLAH!! e_pirate1337's Avatar
    ATLANTA
    Hiram/Dallas area
    and thats how you solve the problem with repeat fails, take the part your putting it on, and/or the old part that worked at one time.
    paint booth
    well shit, its leaking again.
    u sure it's from the distributor? theres a few spots there that it could be either one. that is leaking from.. check like the vtec solinoid, cam seal, & dizzy. put some high temp silicone on .. works out fine with mines
    /Oo ___A___ oO\
    |=_/_______\_=|
    Out in the Boonies
    Hopefully there is no scarring around that area that will cut the o-ring up.
    paint booth
    Quote Originally Posted by DC2NR
    how would i check for that? when i put the dist back on. its alittle tight getting back in. i will check the O-ring thats on it for any cuts or rips tomorrow.
    Take a dab of hondabond and run it around the distributor where it touches the cam cap- should take care of problem
    aye bro .:Stirfry:.'s Avatar
    i was just about to say that.. HONDABOND THAT BISH.. and your good to go:..
    ATL DAsquad Member #9
    paint booth
    Quote Originally Posted by jessetoedtma
    i dont want to put it in the wrong place. could you send me a picture showing where to put the honda bond?
