Results 1 to 21 of 21
Thread: s/c ls civic fuel problem
    Total Insanity helcat17's Avatar
    macon
    Default s/c ls civic fuel problem
    ok this is for a friend of mine he has a 92 civic hatch with a 95 ls motor sporting a full jackson racing s/c setup. hes been having a problem with the car starting everyonce in a while and it dosent realy show a patern. when it happens it still fires just acts like it is getting no fuel. when it happend one time we put a test light on the fuel pump and its getting power soo were starting to think the fuel pump is going bad. recently the starting problem went away but now the car wants to lean out at higher rpm soo now hes wanting to put a fuel pressure guage on the car too see what kinda fpr hes getting at the fuel rail. now the big question hes got is what kind of pressure is he suposed to have at the rail considering he has the jackson racing fuel pressure regulator?
    2009 Honda Civic
    2006 Honda CBR1000rr FS/FT
    http://www.importatlanta.com/forums/...d.php?t=211300
    dc5
    ATL, GA
    what kinda ems? Any datalogs? If not, your just guessing, could be anything...
    macon
    hes running stock ecu i wana say that there are no piggy back or anything compleatly stock motor with a straight up JR s/c setup
    2009 Honda Civic
    macon
    come on wheres scotty? no one knows what the fuel pressure is suposed to be at?
    2009 Honda Civic
    Certified Gearhead brandenj's Avatar
    small town loganville
    i had some problems like that when i was using the jr fpr, once i got it tuned it was all gravy baby. just go get it tuned
    FLOSSIN' MR.EM1's Avatar
    Quote Originally Posted by brandenj
    x2 GO GET IT TUNED!
    dc5
    ATL, GA
    Question
    Quote Originally Posted by MR.EM1
    x2 GO GET IT TUNED!
    with what? He is using a stock ecu.. LOL
    dc5
    ATL, GA
    Quote Originally Posted by helcat17
    Thats not smart, take it off, or don't drive it until you get Hondata inside it, b/c u have no idea wtf is going on...
    macon
    ok guys i know he should get it tuned and hes not arguing that however we need to know what fuel pressure he should have at the fuel rail and as far as stock ecu as long as you have everything that is suposed to be with the kit instaled corectly (and it is) you would be fine on stock ecu i think jackson racing did plenty of research in that area
    2009 Honda Civic
    the county
    the motor is probably being starved of fuel at the higher rpms cause he's running stock motor with a stock ecu.
    so the fuel pump might be having problems keeping up along with the injectors. and i know he's running lean with a stock ecu.
    just get a tune, and upgrade parts to support the s/c(injectors, fuel pump, etc.)
    macon
    ok let me clear this up im not asking if he should get it tuned we all know he should im asking what the FUEL PRESSURE should be at the fuel rail with the JR s/c set up instaled. his motor has been running fine for the past 4 years on stock ecu with the jackson racing fuel controle and s/c instaled soo 4 years and its still not blow i think its set up ok we just dont know what the fpr should be and need too scotty or anyone of his level will know
    2009 Honda Civic
    dc5
    ATL, GA
    what injectors are u running? stock ones?
    middle ga
    its been a while since i have fucked with f/i hondas but i think i set mine at 40-45psi at idle..it will increase with boost...for instance 12 psi will net 57 psi fuel pressure. set it at 45psi and see how it runs...if it busts up while under w.o.t. increse slightly untill it stops.....what do i know..im just a stupid mustang guy! when you coming back from that tdy?
    macon
    ill be back the first week in may im gona try and give you a call today if i get out of class befor you go to work
    2009 Honda Civic
    dc5
    ATL, GA
    mine is set at around 50 psi
    i drive slow im_hung's Avatar
    location, location
    @ 3/4 throttle i was getting about 75 psi on a gsr with a jrsc. i had a similar problem as well... after i switched the fuel pump out for a walbro 225 it was smooth sailing.
    macon
    yea thats what hes gona do is change out the fuel pump but just wants to make sure he has the correct fuel pressure at the rail in the process
    2009 Honda Civic
    the stock pressure should be around 45 +/- at atmospheric (vac line pulled). w/ the rising rate fpr the pressure will jack way up with every pound of boost. if he's still running the stock pump it's crapping out...it cannot stand up to the demands of the higher fuel pressures and flow.
    his best bet is to remove the jackson electronics, rising rate fpr, get larger inj, and chip/tune the ecu.
    Unknown
    Abyss leading the world's "Eternal Tap" was a powerful aion kina demon open, imprisoned in the Abyss long world class wake up and began their revenge on the world. A focus on angels, demons and types of long epic battle between the signs of an imminent storm. To accomplish the mission aion gold of saving the world, players embark on a long journey ... ...
    You may are one of the ... are days may also be a family ........
    But fantasy world with aion money their own will to change is how great things .. and this will be you to decide!
    Fly Song of the buy aion kinabuy aion money eternal .... .. in praise you ....
    Fly Stephen .. .... eternal shining on you in the future .....
    Flying it ..... eternal Tower: Aion wait buy aion gold for you to change the world!
    "I believe an angel, I believe aion kina the devil, believe that" Aion "." In "Aion" world, the player can select two factions: "The Choosen" (God of Mary aion gold Help of Christians) and "The Fallen" (Fall) ... ...
    "Aion: The aion money Tower Of Eternity" is the first online games giant NCsoft Korea has invested in all online games in Korea R & D elite, well-polished production of a new generation of fantasy MMORPG, is a set of development capacity Dacheng NCsoft buy aion kina products.
    "Aion" with "Heaven II", buy aion gold such as the existing MMORPG completely different style. Development team trying to achieve in the game "Let the action to gamers around the world changes, then changes in the world and then in turn affected the relationship buy aion money between players of this cycle," "three ethnic strife of the world", and "science fiction, as well as different fantasy-style original world. "
    Different science fiction, fantasy-style singular world --
    Game designers have made a lot of ideas, hoping to create a different world of the past. Is neither science fiction nor 股票软件 fantasy-style-type style, but not too weird and people can not understand. This point, we can be Game Screenshots, draw the original, and video experience go carefully.
    Screen performance --
    NCsoft's production team 股票分析软件 to make "Aion" inherited Korea online games has always been gorgeous screen with a sense of brisk fighting, at the same time incorporate other elements in the success of online games, for example, "Aion" role in theaion money
    buy aion kina Games can squat, stand, jump (have somersaults effect), can grow wings in the air, can be pure mouse operation or use the keyboard WASD ... ... Yes, World of Warcraft players are familiar 短线牛股 with this particular key bit.
    Players interacting with the world impact --
    At present the existing online games, 黑马股票 including "Heaven II" included, players buy aion gold
    buy aion moneyare subject to the developer to create a world. However, "Aion", the players and games can change the interaction between the gaming world.
    For example, such as a runescape gold village inside the only two shops, if a shop to one of many players in particular, this runescape money shop can buy things that will be more and more prosperous. Another will be with the passage of time constant downsizing, and buy runescape gold finally close down. In addition, the Games of the map expansion is no longer only rely on a patch or information films, players can go through their own action to explore new regions, and even built their own underground city ..
    In this design, each playerbuy runescape money will be able to enjoy the changing world of fun games will bring more changes in the world, gamers will decide their own destiny. At the same time, the aion kina
    aion goldfuture of "Aion" the status of all servers will also be different, because players will be action showed distinct differences in the game world and game environment ... ...
    Three ethnic strife the world --
    NCsoft to absorb runescape sale the "World of Warcraft" and other games in the camp setting forces on the successful experience for "Aion" designed "family day", and "nationality", the story centers around the three to start the war can achieve large-scale "race vs race." Players can become a family day or, while nationality is the monster and NPC.
    However, "Aion" three race is not always rs2 gold hostile. Tribedays and can work to attack the nationality can also be incorporated as a companion NPC, narrowing the scope of the territory of hostile players. Games are not purely PvP so easy, how to deal with will be the third force "Aion" the key aion kinato large-scale PvP. In such settings, "Aion" in PvP combat will become complicated - It is clear that the balance will rs2 money be the development team will resolve an important issue.
    In addition, "Aion"aion gold trying to create a new model for fighting PvPvE, including the design of a variety of new forms of monster,aion money with an unprecedented approach to attacking players, so players in the game full of new adventures tobuy aion kina experiencebuy aion gold a sensebuy aion money of ... ...
    dc5
    ATL, GA
    wtf man?
    1.5T AnTi-PooN's Avatar
    L'villE
