Results 1 to 15 of 15
Thread: cams question
    95 teggy for parts DaRussian's Avatar
    Default cams question
    if i buy some aftermarket cams for a b18 like brian crower or something like that would i need to get the cam gears too? or can i just keep my stock ones? any help is appreciated.
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    the county
    as far as i know of you could keep the stock ones. but why not just upgrade the gears too?
    revolution big mac's Avatar
    yeah it would be best to do the gears too
    stock ones, also depending which cams you will need to replace to stronger valve springs an retainers also
    BTW I have seen cars getting tuned an with over 400HP and the cam gears slipped causing bent valves!
    I hate adjustable cam gears after seeing that shitt happen and I don't trust them
    Hwy 315
    yep, which is exactly why Skunk2 switched to a 6 bolt pattern for theirs. The cam gear won't slip if it's torqued down correctly and in sequence.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Quote Originally Posted by se7en
    -jonathan
    They was all tight and the 6 bolt also....To this day I will not buy adjustable cam gears...they look cool but not worth it.waste of money
    you can run the stock cam gears, but its' best if you get aftermarket camgears as well yo dont wanna go back in there later on
    /Oo ___A___ oO\
    |=_/_______\_=|
    Warner robins ,Ga
    ill make a combo price for you on the BC stg2 cams and the golden eagle cam gears.
    Quote Originally Posted by YouKnowIt
    Best lol....I had many 400 ish HP civics/integras without the need for POS cam gears
    Hwy 315
    lol... I'm sure as the all knowing Tech5million jeenyuz, you understand that lots of power can be unlocked by advancing and retarding cam timing.
    you're telling me, that if you were to run a JG301 cam that JG Engine Dynamics recommends be run at a +2-2 setting... you would run it at 0 degrees?
    -jonathan
    [/URL]
    Thats if you buy those my friend!
    I am not here to have a 500 HP car nor most of these NOOBS trying to ask questions most of them are installing 200ish $$ cam gears on a BONE stock NA car and is a WASTE of money!!!!
    there are only a few people on here that really needs them ....Most people I have seen lately dont need to spend $200.00 + on cam gears an think they will gain 35hp!
    Its a waste and I will say it again , an again unless they are packing something then I can see a maybe!
    But for what these guys need them for (looks) its a waste!
    Hwy 315
    ah yes my friend. In that case you are correct.
    I thought you were saying that all adjustable cam gears were a waste of time/money.
    as usual, reps if possible.
    -jonathan
    [/URL]
    hint hint..this works wonders NOOBS
    http://www.jegs.com/p/Proform/748199/12552/-1
    lolol
    -jonathan
    if you get aftermarket cams you should get adjustable cam gears...just get good ones that have plenty of bolts. like was stated before there is extra power and improved powerband by degreeing in the cams and this is usually done w/ the adjustable cam gears.
    if you have extremely high compression and or oversized valves and are not sure of the clearances then keeping them at 0,0 would be suggested. however, if you want to get the real benefits of aftermarket cams then get adjustable gears and have them degreed in.
    example of why is on a lot of vtec cars w/ aftermarket cams the vtec point has to be so high w/ the cams at 0,0 or else the car loses power w/ a lower vtec crossover. by degreeing them in you are able to bring vtec in lower and not have a power loss and make more power throughout the powerband.
    the real question is...do you really need aftermarket cams?
