Results 1 to 19 of 19
Thread: Tires for Blade?
    Default Tires for Blade?
    Which tire size will be best for the 2000 integra Blade Rims?
    I want something cheap, but still reliable. Thanks.
    go to tirerack.com
    Acworth
    15x 33 1/2
    Acworth
    monster truck style!
    無限 ぽわ D.Choe's Avatar
    Athens, GA
    Quote Originally Posted by jdmjames
    15x 33 1/2
    I think he meant tire size not wheel dimensions?
    Quote Originally Posted by hmong_Spec
    I know OEM spec is 195/55/15, but 205/50/15 look pretty good unless you wanna go with a lower profile than 50.
    If you want something cheap and reliable I'd probably go with some Kumho AST, Fuzion HRi or Falken Ziex-512
    but if you wanna spend a little more my recommendation to you is the Yokohama S.Drive. I have them now and they have held up through ice/snow/rain/dry conditions perfectly
    other better choices would be Kumho ASX, Fuzion ZRi and Falken FK-452, I've had all of the above and recommend any of them to you. just go researching on tirerack.com and see what is best for you.
    which one is the cheapest, and how much for one?
    Quote Originally Posted by D.Choe
    Athens, GA
    195/55 is gonna be cheaper for sure
    on tirerack S.Drive is $71 each
    ASX is $66
    both are 195/55
    thanks man, reps for you.
    Super Handling
    195/55 are pretty expensive tires. I would just opt for 195/60/15's because they are cheaper and you can still get good selection. If your car is extremely lowered, just get the 195/55's then. And I would not fit 205/50 on a 6" wheel.
    And yes, 195/55 is the OEM size.
    N/A POWAH! Gorilla Eg!'s Avatar
    cheapest place to get tires is www.vulcantire.com ....they are cheaper than tire rack! its why I switched! G/L
    reps to all who helped.
    Athens, GA
    Quote Originally Posted by TypeRPersonality
    I kept thinking the blades were 6.5" for some reason...
    yea 205 would be way too wide on a 6", stick w/ 195
    good lookin out
    LS Resurrection
    Fulton County, Union City
    i got 195-50-15 on my si's...turned out great! i'm not sure if they're cheaper though
    LOLOL! fail.
    good lookin out
    The set that's holding the table up under my feet measure 6.5" between the inside of the lips and 7" from edge to edge. I'm going to say they're 6.5".
    A 205 is 10mm wider than a 195, that 5mm wider on the inside and 5mm wider on the outside. 5mm is 0.19 inches. It fits fine. 1,000's of people drive on 205's everyday. You could put 215/45's on there if you wanted to.
    http://www.tirerack.com/tires/Compar...5&startIndex=0
    Super Handling
    LOLOL! fail.
    Are you sure they're 6.5"? All sources point me to assume they're 6" bead to bead seat. And I said I wouldn't recommend 205/50 due to cost and the tire bulging. I know they would fit.
    I dunno, I've been using a scale since I was about 10 yrs old and getting paid to do it professionally for the past 10 years. After nearly 20 years I'd hope I could measure from point A to point B successfully, lol.
    DUH-KYOO-LUHHH
    how fucking hard is it to do some fucking research yourself?
    I wana go fast
    Pike co.
    Kumho Ecsta ASX Tires For $54.75 PM me
    78 camaro build 30% motor-4ci
    Senior Member 4DrTeg's Avatar
