Results 1 to 29 of 29
Thread: JDM ITR CAMS on a stock B17A1 head???
    Certified Gearhead jdmda9's Avatar
    Default JDM ITR CAMS on a stock B17A1 head???
    K guys i need a lil help here. Reps will b given. So i just picked up some JDM 98 spec ITR cams from a buddy of mine. My question is what is needed so that these cams will run smoothly and function without a problem??
    Will i need to get some ITR dual valve springs and retainers or will these be able to just be dropped in without having to modify my head???
    Ive been told that i can run these on my motor straight up as long as i dont rev the fu.ck out of my motor. But i doubt this advice, that is why i ask you guys to help me out here!!!
    Just lmk what parts i need and any recommended brands that i can use so that my motor will run healthy, LAST and still haul ass!!! Thanx PPL!!!
    shhh...
    vtec game scArY. . !
    u can run them on a stock b16 b17 head just dont over rev the bitch.
    Get ITR Valve springs ASAP !!!!!
    I will not use these cams AT ALL unless you replace the springs atleast ITR ones or better!!!!!!!!
    ive heard and done otherwise and been fine.
    +1 same here! your good to GO partna!
    /Oo ___A___ oO\
    |=_/_______\_=|
    you would use stock b16 vavle springs but you want re use headbolts??
    Most kids that does something like this cant help themself but think they can rev the shit out of them... If his stock valve spring breaks his HEAD Is DONE!
    sounds crazy but yup
    its a NoNo until you get ITR dual valve springs and retainers, or something equal or more
    Southside
    Hwy 315
    hmm, below are the part numbers for the valve springs - just referenced in the IBP of the 98-GSR and 98 Type R.
    GSR inner - 14751-P72-003 blue
    outer - 14761-P72-003 blue
    TypeR inner - 14751-P72-003 blue
    kinda weird how the numbers match. My money says he'll be fine running these cams.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Quote Originally Posted by se7en
    -jonathan
    So yes he needs to change them....Good try though
    He has the OLD b17 motor NOT the B18c
    Hwy 315
    hmm, that's what i get for reading too fast.
    regardless, like nomohondas said, as long as he doesn't exceed the stock redline it'll be fine.
    -jonathan
    [/URL]
    -jonathan
    but c'mon now, lets be real. if you had a stock b17 and had some JDM ITR cams in it, and knew that it pull hard up till about 9k rpm... wouldnt you be tempted to hit it that far? lols
    all day
    upgrade that valvetrain son, so you can't say 'naw man i can't rev, ill screw up my head'
    Augusta Ga
    im running 98 spec itr cams in my b17a1 swap and they do great with stock valvetraIN!!!!!!!!!!!!!!!!!!!!!! i love em ...
    93 sol Si
    95 sol S
    95 sol Si
    Hwy 315
    maybe, except that fuel cut on a b17 is 8200. It's like having an lsvtec with a stock LS bottom end... it's called self control and not exceeding your engines limits.
    -jonathan
    [/URL]
    Augusta Ga
    maybe, except that fuel cut on a P61 ecu is 8200. It's like having an lsvtec with a stock LS bottom end... it's called self control and not exceeding your engines limits.
    -jonathan
    fixed
    93 sol Si
    95 sol S
    95 sol Si
    very true richard...yea i doubt ill stop at 8!!! last b17 i had was always taken to atleast 8500..lol!!! most likely im going to upgrade the valvetrain with either ITR parts or aftermarket parts. o and if you happen to know anyone who has what i need, let me know asap!!! thanx for the comments ppl!
    shhh...
    Hwy 315
    Quote Originally Posted by 1SOL2NV
    fixed
    ....which is the stock ecu for that engine, correct?
    -jonathan
    [/URL]
    Don't be stupid get the valves springs an stop being a cheap skate!!!
    Most kids cars that is mildly worked on I don't ever buy there cars because I know something they have done HALF ASS!
    Or fuked something up because they Dont have a clue what they are doing!!
    and think they know it all!
    Augusta Ga
    -jonathan
    Correct !
    93 sol Si
    95 sol S
    95 sol Si
    Augusta Ga
    if my head wasnt recently rebuilt i wouldnt try putting the cams in ..... but mine was rebuilt wit oem stuff .. but no dual valve springs .. just good oem new stuff
    93 sol Si
    95 sol S
    95 sol Si
    Your still pushing your luck!
    Hwy 315
    Tech 5 is teh jeenyuz of awl tymez fo reelz ma nigguz.
    -jonathan
    [/URL]
    -jonathan
    thats it right there.
    -jonathan
    hahahahhaa.....
    Hey just because my car is LOW of oil but running fine doesnt mean not to add oil!
    Hwy 315
    Helpful tips from Tech5 on how-to keep your engine running #153
    -jonathan
    [/URL]
    -jonathan
    yea i know wat to do. i was going to upgrade the valve train anyways just wanted to ask for some feed back. anyways im not a cheap skate and im sure i will spend the best that money can buy on this set up. thanx again people! o and if anyone has any parts that i may need, plz dont hesitate to PM!!!
    shhh...
