Results 1 to 13 of 13
Thread: B18c1 block. Whats the dif?
    Stay Humble
    WV
    Default B18c1 block. Whats the dif?
    Whats the difference in a longblock and regular block?
    and is one better then the other?
    thanks?
    hustler ksniperfox's Avatar
    lawrenceville
    longblock-couple inches longer than regular.
    shortblock-couple inches shorter than regular.
    there are long/short/regular sizes for different generations. but theyre all pretty much the same.
    West palm beach
    Quote Originally Posted by ksniperfox
    too funny
    the old man NAIZBST's Avatar
    long block- complete head and block
    short block- block only, minus head...
    more power with the longblock
    EF Squad
    yup
    lawrenceville
    just kidding.
    shortblock comes with only the block, pistons/rods, crank/crankcase, probably not the head.
    longblock comes with block, the whole bottom end, the head, injectors, both manifolds, maybe starter+alternator.
    Jonesboro/Stockbridge
    just kidding.
    actually long block is head+block complete. no manifolds
    Short block is just the bottom end...complete or non complete.
    More power with a lonblock?
    The term longblock and shortblock come from purchasing crate engine's. As stated above the longblock will include heads or head and the shortblock will be the bottom end only. The physical block built with the rotating assembly. A block on its own is just a block, no crank, no pistons, no rods, but should always have the main caps or you will have to line hone it.
    A B18C1 is a B18C1 is a B18C1, stamped on the block, pistons if stock should be stamped P72. Some people also include accesories with used longblocks, like intake and exaust manifolds, altenator, ps pump and things of that nature.
    Quote Originally Posted by Jenson
    just kidding
    Southside
    Stay Humble
    WV
    so short block is not complete....longblock is?
    Quote Originally Posted by chaseamundo
    correct
    thanks?
    Wow! A long block is the special edition 5-cylinder version. Everybody knows that! The rotational mass of the 5-cylinder is better balanced and runs more smoothly.
