Results 1 to 31 of 31
Thread: Car Shaking Inbetween Gears PLEASE HELP
    Ellenwood
    Default Car Shaking Inbetween Gears PLEASE HELP
    Hey i have a 97 civic it has rebuilt motor D16Y8 head with D16Z6 Block Y8 internals. I have a brand new stage 2 clutch, 12 lbs flywheel, brand new motor and trans mounts, fully aligned. The car shakes violently when i am taking off in 1st gear, sometimes when i shift into 2nd, 3rd, 4th, and not so much 5th. When i downshft it does it as well. If i go into lets say 3rd from second and hold the clutch in then ease off as the shifter is into 3rd it shakes. It seems that if i ease off the clutch it'll vibrate badly. Can anyone give some tips or helpful information i would greatly appreciate it thanks alot! Please help lol im so lost
    Who installed the trans stuff?
    Sounds like bad axles
    wheel bearings? tires? axles?
    could be all the above!
    Quote Originally Posted by Benefit
    barrow county
    not sure.. but try using higher octane gas?
    lmao!
    Quote Originally Posted by eclipse_boy
    I didn't want to say anything. LOL
    Quote Originally Posted by 81911SC
    barrow county
    Ellenwood
    I have new tires new cv axles, octane as well, almost everything is new, if it was the bearings then it wold vibrate constantly correct? and i didnt all the work myself, putting it in as well as the trans stuff i had a hand from my uncle.
    Bearings would when you put more weight on them. Turning etc.
    Ellenwood
    Thats understandable but idk its crazy it cant be that, because its when i take off in 1st like the engine completely chatters violently, only when im letting off the clutch never when im rolling
    IA MEMBER jvillagran2000's Avatar
    EVERYWHERE!!!
    How new are the motor mounts?and are they oem honda?Check the front upper drivers side mount it might be broken.Your having common symthoms of a broken motor mount.
    how did you fill your tranny fluid? did you pump it from the drain hole, or did you actually fill it from the fill hole on the side of the case and allow any excess to drain out from the fill hole before plugging it up?
    if i understand you correctly this always happens as you are engaging and/or disengaging the clutch.
    i had a similar problem once and it was b/c the quick lube place re-filled my trans from the drain hole and overfilled it. the excess fluid seeped out the output shaft bearing and soaked my clutch and pp causing it to chatter violently when engaging/disengaging. a motor mount broke at the same time either by coincidence or b/c the motor kept rocking so badly from the clutch issue.
    my vote is bad clutch/pp possibly from too much fluid and/or broken motor mount.
    Quote Originally Posted by jvillagran2000
    x2 that would be the first thing I check. Also check the bushing on the shift linkage itself.
    maybe they gave you a unsprung 4 puck race clutch on accident lol
    I bet that wasn't even a joke
    I don't pull out... E=MC²'s Avatar
    Where we like our sisters...
    this was happening to a friend of mine and it turned out when we installed his axles the snap ring didnt catch. they were mated together and all it just didnt want to stay. we just pulled the axle and replaced the snap ring. no problems. oh and refilled his tranny cause all the fluid leaked out
    Is your car slammed/lowered? If so I vote axles..
    1998 Camaro Z28 headers/clutch/shifter/full suspension 12.6@122 awaiting install prc dual valve springs, fms pushrods, custom grind fms camshaft: 234/238 .601/.612 114lsa
    1997 Buick Regal GS - stock 14.8@94
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Oct 2008
    LS Resurrection
    Fulton County, Union City
    motor mounts?
    Oct 2008
    Quote Originally Posted by yunglaosta
    motor mounts?
    Possible .. we just dont know
    Banned Apollo's Avatar
    Woodstock, GA
    Im going with your mounts, a lot of people dont change thier mounts, which it is recommended that you do, no matter if you think they are still good, its saves you the trouble down the road.
    LS Resurrection
    Quote Originally Posted by STRteg
    hahaha yeah! hmmm who knows....most likely its da motor mount my mounts are fugggged up and i have alotta vibrations. just changed my rear mount today and it helped ALOT
    Oct 2008
    griffin ga
    Are the flywheel bolts all tightened correctly if not a lightweight flywheel can really rattle but just a idea
    YEAH! bRiAnMcIvIcS's Avatar
    Its probably the shitty oem driverside mount, all 96-00 civics bust that mount after time.
    I would recommend buying the innovative driver side mount, if thats the problem.
    Link:
    http://www.innovativemounts.com/Prod...ductCode=10010
    Oct 2008
    Quote Originally Posted by bRiAnMcIvIcS
    Link:
    Yeah my 97 civic mount when out when i had it that was a rough cross over between gears and taking off
    freezrburn frostbyte's Avatar
    douglasville
    jus sold my 89 accord and i had the same problem it was wheel hubs the bearings were shot.. couldnt tell anything was wrong unless u engaged the clutch the extra pull is wat caused them to bind and shake like a fat woman chasin a twinkie
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
