Results 1 to 15 of 15
Thread: 1993 Civic-- NO SPARK
    Default 1993 Civic-- NO SPARK
    New:
    -plugs
    -wires
    -coil
    -ignition module
    -rotor button
    -cap
    The coil is not sparking. Like I said, it's brand new, also the ignition module is getting power.
    Any ideas of what to test or replace?
    It's all about JDM.
    CA to GA
    does the motor want to turn when starting it or nothing at all...Check fuse box, to see if any fuses blown...
    Yes, the motor turns over, and both ECU fuses are good.
    u still have the msd
    Different car, but no on both cars
    roberta
    no idea but best of luck evan
    bad ecu is all i can think of.
    Oct 2003
    ground wire bolted to thermostat housing...check for corrosion.
    main relay under dash
    ecu fuse
    main fuse
    EVAN = FAIL
    Quote Originally Posted by Annihilation
    ecu fuse
    main fuse
    thanks for the ideas, will check them out tomorrow.
    I know the ECU and back up fuse are both good though.
    TeAm ToTaLMaDnEsS .. JuLiaN_TM's Avatar
    SaNdY SpRiNgS / MaRiEttA
    hey bro check the dizzy ... that happen to my civic .. i bought all the parts u got and it was the dizzy ... g/l
    Quote Originally Posted by JuLiaN_TM
    I put one in that I got from Joshua
    chill six7teen's Avatar
    Columbus
    i know this may sound absolutely crazy, but check your SRS fuse under your dash board.. when changing my obd0 crx to obd1, i wasnt gettin any spark.. i found out i was missing the SRS fuse, and just to see if it would do anything i got put one in... cranked right up.. i havent read up on the schematics of why it controls the spark, i just know it has something to do with it.. but GL either way!!
    Check your timing, igniter, senors in the dizzy, recheck the ecu make sure its getting signal.
    North Augusta, SC
    Dang Evan... you are really taking away from the theory Honda=reliability. lol jk bro. Hope ya get it figured out.
    Back to being stock and slow
