Results 1 to 25 of 25
Thread: gsr build cant figure out why its burning oil
    sleeve me please?
    monroe
    Default gsr build cant figure out why its burning oil
    i built my GSR and ran it for 650 miles it was tuned right when i built it
    i pulled out of somewhere and ran it to about 7500 rpm and let off after i let off i looked in my rear view just to make sure there were no cops and i saw smoke i revved a little bit and it started throwing it out more and more
    I built it setup with
    82 mm overbore pr3 pistons
    stock crank
    stock rods
    je rings
    the head is port and polished head
    stock valves
    stock valve guides
    felpro valve seals
    titanium retainers
    dual springs
    i took the motor apart and checked the piston it is cylinder 1 thats burning
    i checked the piston it was fine and i checked the rings and they looked fine i didnt see anything wrong so i put them back in and i sent my head to the machine shop and got it checked and it came back with nothing wrong so i put it back together thinking the rings might have just come unset and it still burns oil
    HELP HELP HELP!!!!!!!!!
    y did u take it apart. y not just do a compression and leak down test.
    x2 on that
    When you installed the rings, did you check to see if the marking were up and were they position right? And when the pistons was in did you check for play? Did the new valve seals seat in right? I would have used oem valve seals. When you pull the header off did you see any oil in the exhaust port?
    Oct 2003
    DiD YOU CHECK THE RING GAPS? Cleaned out the factory catch can in back? Did you check the ringlands to make sure there is no hairline crack? how about the clearance between piston and cylinder walls? also clearance of the valves and valve guide......they can be worn out
    sleeve me please?
    monroe
    Quote Originally Posted by mp82
    x2 on that
    ok all the things you listed yes they are done right an di did check and there is oil coming out of cylinder 1 exhaust on the muffler and it has flowed al the way to the cat and it is pretty thick then when i put it back together last night efter cleaning everything i cut it on for about 1 min if even and took the header off and it is completely covered
    help man!
    sleeve me please?
    monroe
    Quote Originally Posted by Annihilation
    valves are fine my machine man checked the guides and the valves before putting it together
    everything has been checked except for the hairline crack i am taking it back apart today so??
    DC5-R
    Gwinett
    probably should have used OEM rings instead of JE. Thats just my opinion though, heard bad things about their rings.
    sleeve me please?
    monroe
    hmm finding oem 82mm rings cersus JE hmm whats better
    sleeve me please?
    monroe
    ok i put piston 4 in cylinder 1 and piston 1 in cylinder 4 just to see what happens and there is still an oil leak on cylinder one so i have switched them back and narrowed it down to either valve seals or i cracked my head somehow???
    Alpharetta, Ga
    ^please tell me your replacing your headgasket every time your tear down your block to NOT fix it. check those valve stem seals. ever thought of a compression test before you broke down your block like what.... 4 times?
    The G Spot Hero
    op u my friend are a tard. your going about fixing the hardest way u can.
    Alpharetta, Ga
    correct... and the longest possible repair too...
    why dont you take it to someone who knos something about a internal combustion engine... have you even looked at either the topside exhaust or intake valves through the intake and exhaust ports. to see if oil is in your case... POORING down them... when you start the car, can you tell if the oil is being burned, like going through the motor and combustion camber or just leaking out the exhaust valve stem seals and burning up in the exhaust?
    The G Spot Hero
    i forgot to add get someone to gauge that cylinder bored, might be off.
    Alpharetta, Ga
    or a compression test can give you a indication of what and what is NOT a problem. like rings.
    The G Spot Hero
    sleeve me please?
    monroe
    i aint got nothing but time so i am narrowing it down little by little the block is fine yes i gauged the cylinders and the rings are fine. the oil is making it into the cylinder but not a lot it is coming out of the head i just dropped it at my machinest he is checking for cracks and anything and i am also geting him to replace the valve seals!!
    Alpharetta, Ga
    it doesnt matter how much time you have do you know how much of a waste of money all that is... you could have fixed it the first time with out taking the head off if it was a just stem seal... geez....
    The G Spot Hero
    Ive seen several motors with bad oil control rings still pass a compression test, they aren't always useful for diagnosing oil consumption. The compression rings seal isn't a good indicator of oil usage.
    Alpharetta, Ga
    but it can help indicate a direction you should go to help Di-ag a car...
    The G Spot Hero
    The last 3 honda engines ive pulled apart all burned oil, and all 3 had perfect compression. All 3 of them also had seized oil control rings after disassembly!. Not saying thats the prob here but its not a end all solution.
    Alpharetta, Ga
    did you see the word help at all in that sentence... or are you just dense?
    The G Spot Hero
    Must just be dense
    Alpharetta, Ga
    ok just wondering...
    The G Spot Hero
    sleeve me please?
    monroe
    wtf ever
    Quote Originally Posted by jap_racer1 View Post
    wtf ever
    what whas the problem? did you fix it? i know it was long time ago but can you please let me know i have same problem
    This thread has been DEAD for 4 years man!
