Thread: MKIII
    THAONLYDAW/SISEATS
    Winder
    Default MKIII
    will a 2JZ-GTE fit in a 88 turbo?????
    and are there any front end conversions for these cars?
    Hey there,
    Yes, the 2JZGTE does fit. For the '88, you need to either swap in the crossmember from the '89.5 or later, or use a set of aftermarket mount brackets.
    On the 2JZ I think that there's a small part of the firewall that needs to be "relieved" slightly, if you're going to use the stock twin turbos.
    You'll want to make sure that you either get an engine with the right oil pan configuration, or change the oil pan. You need the rear sump, and since most 2JZs come from Aristo cars (front sump), you need to get a 2JZ or 1JZ rear sump oil pan setup from a US 2JZGTE (Supra) or a 1JZGTE oil pan (Soarer or Supra).
    Plus you'll need it wired up: http://www.phoenixtuning.com/
    -Doc
    aka Paco flyNhawaiian's Avatar
    Columbia
    to what dr. tweak said.
    also on front end conversions yes they do have one, but i think it sucks lol
    old skool soarer front end
    2002 GS300 Sport Design
    92 Supra Turbo
    97 SC3 RSP/Black NA-T
    95 SC3 5spd black intr, VOLK, GREDDY, HKS (sold)
    95 SC3 Twin Turbo (sold)
    THAONLYDAW/SISEATS
    Winder
    Quote Originally Posted by Dr Tweak
    Hey there,
    -Doc
    thanks bro... how much for wiring? i can get it in and ready to go but might get stuck on that... and now i think about it... what trans would you use?..
    its auto want to go manual...R154?? V161????
    THAONLYDAW/SISEATS
    Winder
    WOW i will leave it alone............
    Quote Originally Posted by flyNhawaiian
    That wiring conversion is $450 plus $40 for return shipping/insurance. (You need to provide the original engine harness and the new engine harness).
    For auto/manual I would run an R154, they are pretty easy to get, fit right into the Mk3, and work extremely well. Bear in mind that if you get one from an MK3 Turbo, you'll need a 1JZ bellhousing to bolt it to the 2JZ. (We have those too).
    -Doc
    THAONLYDAW/SISEATS
    Winder
    -Doc
    ok i will give you a call in a couple weeks when its in and ready for wireing.
