Results 1 to 17 of 17
Thread: alright more questions. crx dash in a 4door
    Default alright more questions. crx dash in a 4door
    i know it's a bolt up swap in the hatch wondering what the differences if any are on the 4 door...
    what time is lunch?
    woodstock
    Yeah there is some slight triming at the front, rode in a 4 door with one and the guy said he had to trim a little off of the front to get it to sit right on the firewall.
    it looked hella sweet in there.
    alright everyone guess what i did yesterday
    more pics to come
    Snellville/Statesboro
    how long it take you to pull the dash out?
    UPROOT Photography FTW
    Default um not too long
    lil over an hour i think...from start to finish the whole swap took over 4 1/2 hours but i had some wiring issues due to the tweaker that owned the car before me...there was actually a wall switch wired in the center console (like a light switch, and all it did was turn on the door ajar light) lol.....and i had to beat the floor down where someone didn't put the jack in the right place. but it looks great... there's a small gap on the left and right side barely noticable. i'm making a small write up that descibes the main parts of how to do it because it's not just a bolt in swap lol
    deff post sum pics when it's all done and the interior is back in place.
    Southside of The Jungle
    of finished product
    i need the cover that goes under the steering wheel : (
    heres the small gap on each side you really can barely tell and im going to put some foam tape there just because im picky,but it's really not needed
    Not bad I was just going to get the part that goes around the cluster.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    looks good!
    thanks just one of many more million things I hve to do. Next I'm putting some backdoor door handles up on the front.
    college park
    ^^^^smart mod i did that on my old accord and got a keyless entry alarm i also removed the door locks you know the part that pops up on the inside so if i left the windows cracked someone could pull it up im def feeling your 4 door
    for the part under the dash i think just about everyone here has that issue the little tab breaks so easily i found mine at the pull a part on moreland ave they do have quite a few 4 doors in there but finding one with black int. is gonna be the hard part. i go out there alot just to learn how to take stuff off of my car so if i see one ill pick one up for you
    now with LSD
    i need one for the rex. i just wasnt thinking when i pulled this dash and forgot it. it was so hot at pull a part that day. i got the dash for freaking 27 dollars!! yay lol. so if you see one for a 90 91 rex and want to grab it that would be so sweet.. i won't be working on my ride for a while though. due to the fact i'm getting married september 7th then i'll be in mexico for a little over a week. i think my swap is being put in while i am away though assuming i can get all the parts ready for my friend. i gotta get some knuckles and hubs because my drivers side is from a dx and passenger side is an ex lol...
    quick question does anyone here know the procedure for the ek armrest with the crx like how well does it fit what all pieces do i need etc.....?
    1.5T AnTi-PooN's Avatar
    L'villE
    ^^^^^^^^they have a jdm ef one on ebay right now
    ECEFC.com
    Quote Originally Posted by jriley60
    I'll post a write up, give me a sec
    ECEFC.com
    reps please
    Quote Originally Posted by doublethink
    Why do this?
    It looks better then the jdm armrest when done right, and costs a fraction of what the jdm piece usually goes for. It is also wide enough to hold two drinks in it, and Honda has a cup holder accessory for these armrests as well.
    What do you need?
    - 88-91 CRX
    - Armrest from a 96-2000 Civic (often nicknamed EK chassis)
    - One can of Flat Black Interior Paint
    - Hand File OR a Dremel (Highly Recommended)
    - Two Metric Bolts - 8 x 40mm
    - Two Black Screw Caps
    How is it done?
    First is the shape of the front. I don't have any images of this part, but you must Dremel the shape of the CRX shifter console into the EK armrest.
    My only advice is to go slow and take too little rather then too much.
    Next is the color. The problem with EK Civics is they almost always come with Grey interior.
    That is where the paint comes in:
    This is a paint found at PepBoys. It's pretty much a perfect match for the black Honda used OEM.
    ****NOTE: There are two blacks in this line of paint, MATTE and GLOSSY. The GLOSSY cap is shiny, DO NOT GET this type. Stick to MATTE (dull cap) for a real OEM finish.
    And most importantly: DO NOT SOAK OR DRIP THE PAINT, IT WILL RUIN THE FACTORY TEXTURE!
    Use 3 or 4 light coats to cover it.
    After I finished cutting and painting it:
    Next you have to measure and drill the two holes for the mounting screws:
    You can get these screws at most Home Depots, these are the exact ones with the proper threading for the factory holes in the floorboard of the car.
    After you bolt them in you use the screw caps to hide the bolts.
    The easiest place to find these black screw caps is in "license plate mounting kits" at your local auto parts store.
    If you followed this it should look pretty much like this bolted in:
