Results 1 to 14 of 14
Thread: gsr head b16 bloack
    Default gsr head b16 block
    Im wondering if i will be ok by turboing my motor.its an gsr head on a b16 block lmk thanks..choabie
    Norcross
    it all depends on how many pounds u wana run
    Default hey
    i was hoping at least 8-10 psi dd on 4-5.an about how much horse power should i make?
    Out in the Boonies
    why's it running a b16 block?
    IA Member grady156's Avatar
    Bainbridge
    With that setup I believe you are running a little lower compression. That will ease on tuning a little. But other than that I dont think it would be any different than boosting a b16 block.
    Default hey
    Quote Originally Posted by grady156
    so what kind of numbers could i be lookin at with an greddy turbo kit an 880 injectors on 8-10 psi
    Lots of miss information going on. GSR head on a b16= MORE compression not less. This being the all motor forum I would have figured you people would know that the GSR head has smaller combustion chamber yeilding more compression. On that note this should be in the FI forum. It doesnt matter how many psi of boost you run, it depends on the size of the turbo. With a greddy kit you certainly do not need 880cc injectors, more like 450's.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    Default hey
    Quote Originally Posted by josh green
    for some odd reason they put an gsr head on a b16 why i dont know.but some ppl sayin its the same as a gsr is that true?an itss an t25 turbo
    i got the same setup. its almost 11:1 compression. too high for boost. 5 psi would b all id run IF i boosted it bc stock piston ring gap at that compression with boost is not a good combo.
    Out in the Boonies
    Quote Originally Posted by choabie
    Wouldn't you be running like a b16 and not a gsr. You would have a slightly higher compression, but you would be losing alot more power/torque due to runnin a smaller stroke with a b16 block and crank. Correct me if I'm wrong here.
    Quote Originally Posted by DC2NR
    gsr head + b16 block? why go that route for? might as well run a full b16 motor..
    /Oo ___A___ oO\
    |=_/_______\_=|
    High compression turbo cars will spool quicker, be more responsive and make more power with less boost. Of course you cant run big boost on pump gas but with a proper tune, "BY BATLGROUND OF COURSE", it should be fine. Just keep the boost at a safe level and don't get greedy with the quest for power.
    you are right, you will loose power and torque if you run the b16 bottom end. But he will be raising the compression by running the b18 head. So you gain a little of the power back there.
    ill tune the sh!t out of an vafc. batlground callout!! j/k. lol!
