Results 1 to 40 of 47
Thread: Type R motor what to do?
    Default Type R motor what to do?
    Im dropping a type R motor in my new civic and i wanna give it alittle more power but i dont care to do anything crazy to it. Im doing the usual headers, intake, exaust, dress ups, flywheel, upgrade the clutch, and do a good tune. but i was wondering if i up the injectors any if that would help at all? that and im not sure which would be better to do, either get a VAFC or just get an upgraded ECU. Like i said i dont wanna do anything to crazy to it cause im makeing this my daily driver and im trying to keep the AC and all in it. anywho if ya have any info and such please let me know. thanks.
    West Staines
    leave it alone.
    your moms house
    leave the the vfac alone they are crap just get a chipped computer and tune it and call it quits. the injectors won't do a thing for performance either. if you want to some to give it a little extra kick pick some smaller cams that can be used with type r valve train and tune it.
    Don Mon SiRed94's Avatar
    Morrow 30260
    yeah the mods you listed are about all you really need to be satisfied... but forget the injectors and vafc as already stated... also, look into a really good header like rage/hytech, because something like a DC sport won't be much of an upgrade from stock...
    I like steak Dirka Dirka's Avatar
    westchestertonfieldville
    Yeah, as previously stated do the mods listed minus the injectors. Buy hondata s100 tune it and call it a day.
    leave it stock and ride out
    get a tryi-y header from me
    get an ECU from me
    Tune it
    /thread
    tryi-y header?? what ECU do you have? Yeah i just want alittle bit more then what i have.. but dont we all say that at one point or another?! Thanks guys for the imput. I wasnt sure if upping the injectors would actually do anything. ive heard mixed results on it. But if you guys have any other suggestions please let me know. And i'll hopefully have the car up and running by the end of july so i can bring it to atlanta.
    Header that is proven to make 10whp just by bolting it on
    http://www.importatlanta.com/forums/...d.php?t=171361
    ECU wise i have OBD1 CROME ECUs that you can tune with. If you have an OBD1 ecu already then i can chip it
    injector wise, stock is good for 200whp so dont waste money upgrading it.
    Around metro-ATLANTA & IA!!
    i dont know what model civic u have but if it's a EX, just get the stock ECU(p28) and get it chipped with a temporary basemap until u can go get a dyno tune,unless u plan on leaving your car for them to do everything, or if u dont have one u can always purchase an ECU already chipped, they go for an average of $180-$200. What i would do first is buy the baller headers from MR.KIDD before he runs out!! . save up more money and get a set of stage 1 cams, (PRO1's from skunk2,buddy club +3, dont get cheap shiet cuz most likely they'll give u less power than your stock type-r cams.
    tryi-y header + PRO1's + dyno tune= satisfaction guaranteed......
    G/L with your plans
    Senior Member 9ussy's Avatar
    Quote Originally Posted by Long's_NA
    G/L with your plans
    x2
    Dude you guys are F**K*N AWSOME!! PM me and lemme know how much they run for. I was thinkin of just chipping it Instead of hondata. It sounds cheaper and has the same eficiency. But yeah its just an 00 Civic EX. With getting stage one cams i dont have to do head work will i? Like i said i dont wanna spend ubber amounts on money on the motor considering its my daily. i just wanna make it alittle bit more then it already has and make it look decent. Im going to track down a del sol to do my fun stuff with! But thanks for the GREAT imput guys.. and please keep them coming!
    Augusta Ga
    the most expensive thing they have said is cams and tune .... be prepared to spend 3-400 on the tune and 300-500 on a set of new cams ...... g/l and enjoy the Type r motor .... heard its real fun .
    93 sol Si
    95 sol S
    95 sol Si
    itr ftl
    Augusta Ga
    ^^^^ ok ...
    93 sol Si
    95 sol S
    95 sol Si
    you dolnt really need cams, the ITR cams are fine, they can support 190-195whp easily with the mods i listed.
    The stock OEM head runs out of flow at that HP level so there isnt any reason to go with bigger cams IMO
    hehe
    he has an ITR Motor not a SOHC
    I sure does! I so cant wait to finish it up so i can drive it and go have some fun!!
    your moms house
    what i was just about to say.
    if you start trying to mak more than that you needs to start helping airflow into the engine.
    and when the hell did pro 1's become stage one cams like bc 3's lol
    well they have a smaller number in the name duh!
    eh.. its whatever works! i knew what he ment...Anywho Ya'll are still awsome! Please keep the info comeing... Any suggestion helps..
    your moms house
    rage tri y header
    full 2.5 inch exhaust
    adjustible cam gears
    some small cams i.e. toda a's skunk old stg1's bc3's etc.etc use stock valve train
    chipped p28 tuned on the dyno
    short ram intake with a bpi stack
    should put you at around 185 190 whp with a really good tune. that should be enough to make the car fun to drive and keep it reliable. end of story
    Thanks mota... hopefully itll be done within the next couple of months.. my next trip to GA hopefully i'll make it to a gathering
    N/A POWAH! Gorilla Eg!'s Avatar
    a good set of cams and header will do great for you.....please check out the "Bisimoto" link in my sig he offers the best products in the industry at a good price
    Hwy 315
    leave it alone.
    advice worth repeating
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Weekly Gwinnett/Junciton Meet
    Hit VTEC all around town...that's all i can think of.
    Cambodia
    Quote Originally Posted by se7en
    -jonathan
    I'll quote and repeat. Don't touch it. You'll be more than satisfied coming from a single cam. If anything, before the motor goes in, put a new clutch in it.
    So far i have on it Intake, Light weight pulleys, fuel rail, FPR, NGK plugs and wires, Exaust, and normal dress up stuff. Im planning on putting on cam gears, Cams, Headers, Light weight fly wheel, new clutch, maybe if needed, springs and retainers, engine damper kit, MSD, and some other things to help it Just want alittle more power with nothing serious involved.. I was wondering if i uped my intake manafold if that would help at all? any ideas or suggestions on that one? and im thinkin of an LSD tranny... not sure yet.
    your moms house
    Quote Originally Posted by Kasper
    most of thses are a waste of money and don't do jack for performance
    Shane do you really understand what a Type R motor is? Its a Beefed up GSR an Honda did great things to it to make it what it is leave it alone unless your going to spend thousands to make everything forged an boosting it...N/A its built great already as it sits..Many people would kill to have your cams an valve springs for there Gsr an B16 so leave it be..I think all you need is a Good header an a Great Tune an it will make more power then all those silly add ons you got.
    Stang Mod slostang's Avatar
    Southside
    Quoted fo troof!!!
    okay.... well i wanted the fuel rail just for look, if i dont need the FPR and the pulleys then i wont bother putting them on. save me some money and put it towards the other **** i want for it! I was told she just got outa the paint shop and i should have her back shortly so i can finish up with the motor and put the audio system in it!! IM SOOOOOO HAPPY!!!!!!!!!!!!!!!!!!
    N/A yeah!
    good luck man very fun to owen and drive one
    92 EG GSR Supercharged sold
    93 EG JDM Type-r- GONE 2 Bro
    Yeah i guess i have to say tom H is to blame on this one! I dont know if he still has it but when he had his Silver Hatch with the type R in it i fell in love with it! and now that i have the chance to do it it and just put alittle bit more in the coupe i decided i'll try it! Plus i didnt want anything major in there cause it is going to be my daily driver. if figured this would be perfect.
    :) LiL PaKi's Avatar
    in my own lil world
    type r motor what to do?
    Sell it to me.. duh!
    HAHAHA i dont think so! ive been waiting for this for a long time!
    . eg mike's Avatar
    ga
    Agreed!
    Check List:
    Intake
    Good Header
    Exhaust
    Chipped p28 ecu
    Tuned
    Adjustable cam gears
    exxedy stage 1 clutch
    99-00 SI anti-roll mount (driver side) for a/c w/ b-series
    Just like Mr Kidd stated, don't put the cams in there it would be a waste of money same with the hondata!
    Your looking to get around 200 whp which is tons of fun in a civic!
    ya'll are flippen awsome! i wish i would have had more time in atlanta to see ya'll. hopefully next time.
