Results 1 to 22 of 22
Thread: Would i be SAFE for boost with just certain parts?
    SwiperNoSwiping!!
    Question Would i be SAFE for boost with just certain parts?
    what if i were to only install new forged pistons, piston rings, new headgasket, ARP head studs, valve springs, adjustable cams and Crower Stage 2 cam gears, but have everything else stay OEM, would it be safe to boost and daily drive my B18A1 on ~9 - 12psi?
    (naturally, the fuel upgrades will come along too...)
    Also, would it be cool to install those parts and run on them without boost for a little while until i could get a turbo kit together?
    DA KOOLAID MAN MIKE.P's Avatar
    conyers
    if your going to do pistons why not do the rods while your there?!?!
    06 rr rs
    03 rr evo
    6xx hp @ 3x psi *sold*
    http://www.youtube.com/watch?v=99CakHqCUMA
    SwiperNoSwiping!!
    cuz the build budget im on wont allow for all of it AT ONCE...
    i got a stock gsr with 7 psi and it's running perfect no smoke at all best it ever been
    Oct 2003
    Mike P makes a great point. There's no need for just doing pistons since you'd have to go into the engine anyways. Unless you like S shaped rods from a boost spike you had no clue was gonna happen. How about pistons and rods w/ the arp head studs and copper head gasket and come back for the rest of that later on? It don't take long to swap the cams/valve springs out vs. taking apart the bottom end to only swap the rods which means taking the head off yet again to remove the pistons. That's what I'd do.
    Out the game again!!
    southside of the border
    always got a solution huh
    Soon!!
    SwiperNoSwiping!!
    Quote Originally Posted by 93db2
    lol, it actually sounds pretty good to me
    clayton county
    you're going to tune it right?? hopefully u do.. people run stock with boost... the good ones have a tune in their history
    I give out reps....
    Oct 2003
    Damn skippy
    Don Mon SiRed94's Avatar
    Morrow 30260
    yeah man... just leave the bottom end alone until you have the money to do it all at once... because you will end up just double working yourself... plus you will have to balance the bottom end for the pistons and then go back and re-balance it after you get the rods.... but yes, it is ok to drive the car without boost with forged internals, in fact I would recommend it during the break-in period and then put on the boost and switch to synthetic oil afterwards... I would just get the money up for the turbo kit, put that on and run that on stock internals until you get tired of it and then save up the money and build the bottom end when you can... but just don't start putting parts on the car until you have everything for what you are doing....
    if you're only going to run 9psi you can boost first...my stock internaled single-cam non-vtec just hit the 5 year mark running 9-11psi. if you're going to spend the time opening up the motor go rods, pistons, headstuds. nix the cams, springs/ret, and cam gears until later when you do some head work and really up the boost.
    tuning should def be in any budget you do.
    SwiperNoSwiping!!
    So, i can really run boost DAILY DRIVING, safely?? 9 psi? NO internals?? 100% stock??
    lol thats a concept i just cant seem to get through my head for some reason
    Plus, i think my motor needs to be rebuilt anyways because when i was on the dyno and they pushed it toward the redline, a lottta white smoke started flying out my pipe. Also, the fact that it only pushed MAX 96.8 whp makes me think it needs a rebuild too.
    Oct 2003
    ^^Yes. It's very do-able. Just make sure you tune it or your engine will make soup of itself.
    SwiperNoSwiping!!
    Now thats always what ive been somewhat confused about too..
    If i were to install the turbo myself, AT my house, how would i get it to the shop? Would it be somewhat safe to drive it over there without a tune or how would i do that part of it?
    EE OG Revmaynard's Avatar
    That's fine, you can drive without it being tuned, it's just better to be tuned when boosting so you know everything is working together correctly.
    Bozzio for president.
    Turbo-Wired
    East Cobb
    You can also just read the boost meter (You will install a meter, right?) and keep it below 1-2psi the entire trip to the shop.
    RE30
    block now, head later and get a good tune. block is what u really have to worry about if u boost.
    EAT DOG white_rice's Avatar
    lawrenceville
    if you cant afford why not just save up to do the whole thing at once?
    SwiperNoSwiping!!
    Quote Originally Posted by Kaiser
    yeah im gonna install one
    Certified Gearhead EK Hotch's Avatar
    Canton
    You can also take the spring out of the wastegate if it is external or disconnect the wastegate actuator arm if it is internally wastegated to keep the turbo from boosting.
    Swamp
    Turbo-Wired
    East Cobb
    Quote Originally Posted by EK Hotch
    Yeah. Or you could just drive like Grandma and not have to worry about fiddling with your wastegate at all. I'm just sayin'.
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by GM_TUNER
    take it from me. If you have everything already disassembled, do it right the first time. Take your time, get all the correct parts. It'll save you a lot of headaches in the long run. 2nd, you can boost on the stock componets. Juust tone it down to like 6psi.
    The Carbon Fibered R6
