Results 1 to 20 of 20
Thread: shop to install hood pins
    Certified Gearhead ghostrida3's Avatar
    Default shop to install hood pins
    looking for a shop to install hood pins in marietta. also how much should i expect to pay?
    JDM TYTE AnthonyF's Avatar
    I did my own. check sig. It's not that hard homey. All you need is a drill and a measuring tape. MEASURE A LOT. dont rush.
    The Carbon Fibered R6
    ima little nervous about drillin into carbon fiber. plus i dont have a drill.
    rent one from HD, but to have a reputable shop JUST install hood pins is gonna take awhile. Most the shops are busy with big projects and have a waiting line.
    any tips for drillin carbon fiber?
    ever done cf....if I had CF i prob wouldnt drill holes in it. Search google, i am sure there is a write up about it. The reason I wouldnt do CF is b/c it can fray and start pulling apart. Maybe there is a chemical or glue you can apply to the hole that will hold it together.
    other than hood pins is there any other safty precautions i can take to make sure the hood doesnt blow up while driving?
    yes. put the stock latch on there.
    do not take your car to a shop to put hood pins on.
    a big strap across the hood will work. I do know what u mean, those CF hoods like to flex (cheaper ones). If you get a Siebon (sp) those things are very strong but expensive.
    my stock latch looks like its welded onto the hood. either way the one on the cf hood is almost an exact macth. i still wouldnt trust it just cuz of how light it is. i think ime gonna rent a drill and try not to screw up my hood.
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    I think bucky can do it for you. PM HIM..
    NIKON Squad member 05
    Mah shit thread
    Quote Originally Posted by ghostrida3
    your f ucked
    if u do your own drilling, do it slowly. step up bits slowly. and take in account the bend of the hood (angle) b/c you need to drill in that angle or in the angle of what u will be mounting the pins to. I will try to get pics of mine for you.
    I drilled my carbon hood, just tape it off. and Drill through it super slot.
    blank
    nowhere
    i have done a few i can knock it out in a day. if your interested pm me
    southside
    why not u doin that for him?? you re lot helper.
    Mah shit thread
    take it to bucky. get it done right the first time.
    whats a superslot?
    Acworth
    you dont need pins- I have had a CF hood for 4 years no pins- stock latch and I have had no problems ever!
    installed the hood. the pins were the easiest parts i spent 3hrs trying to get the hood to latch. and 30 mins installin the hood pins. drilling into the carbon fiber was alot more forgiving than i thought. thanks fr the help
