Results 1 to 40 of 53
Thread: WTF AXLE NUT
    Default WTF AXLE NUT
    alright well im trying to get out the 32mm axle nut on my DC2 and i just went through 2 1/2 inch wrenches one snapped in half and the other bent 90 degrees (using a BMFBB)....ive also tried my impact gun but the stupid thing wont budge...and yes i expanded that stupid little notch in the nut. any ideas?
    SwiperNoSwiping!!
    did you use some PB-Blaster, or some WD40?? To loosen it up a bit?
    Hampton, Ga
    i had that problem on a eg. I cut mine off but you might try DRYICE
    well i just spent the last 10 minutes jumping up and down on my torque wrench like a pogo stick...well the needle is bent way past 250ft/lbs now...
    Acworth
    Having the same issue on my EG
    ^^ let me know how you get it done...it was almost the same thing on the driver side axle but the axle was just stuck in the hub, nut came off fine...i had to beat the living **** out of it and mushroom the end of it but i can grind it so the nut fits...
    is better than you..
    Somewhere you're not
    tried soaking it in PB blaster yet?
    Southside of The Jungle
    lol we broke 2 rachets when trying to get my friends off and 2 when trying to get my brothers off but the impact got it off
    ALL CAPS JITB's Avatar
    take it to a tranny repair shop, and they will get it off in a minute! either that or keep pushin...lol
    Scottish Scotsman's Avatar
    on the road to recovery
    you need a long a$$ sissy bar , find you a bar that will fit over your handle on your ratchet , the longer the better , i just used a 13' piece of pipe to break one loose on my bro's crx
    ^^ thats exactly what i did , snapped one ratchet and bent the other one 90 degrees...
    oh, how hard is it to take a motor out from under the car? im guessing normal jacks can not jack the car high enough? it seems alot easier than pulling it from top
    dunno , i've always pulled it from the top , do you have a breaker bar?
    boosted hatch
    its actually easier to get the motor out from underneath the car.Just put a tire there to sit it on.
    Might have to take the head off so you can slip it under
    ^^ taking the head off to slip it under is definitely not easier
    Quote Originally Posted by Benefit
    Wait, you use the torque wrench to open? Torque wrench is used to tighten only!
    its the only 1/2 inch wrench i had left hehe
    Duluth, GA
    had same problem on my dc2, had my mom hold the brake and I just went to town on it with a breaker bar for about an hour till it finally came loose
    i think if i heat it up and impact gun it...
    SPUNKY MONKEY importking73's Avatar
    yea heat it up wit a torch then it will break loose
    Hampton, Ga
    Quote Originally Posted by importking73
    lies............... go buy a nut splitter or a drimmel or air chisel and get it off. Its seized and isnt gonna brake loose no matter what you try. Last time i had that problem went through 3 breaker bars, A torch a ratchet, 250ftlb impact with not luck
    Put the breaker bar (or whatever you're using) on the nut with the bar resting on the ground. Hold the bar on the axle nut, and get someone to get in the car and dump the clutch. It'll break it right loose.
    Quote Originally Posted by cadcivic
    in what world is that easier.
    thats correct it get glowing red hot then hit it with a good impact gun like a IR 2135Ti.
    Certified Gearhead yungdz's Avatar
    Sandy Springs
    Its easier to pull a motor from the top unless you have a lift, I hope your using Craftsman tools!
    Quote Originally Posted by Init2winit
    Flowery Branch
    you need a bigger impact, i got a 1200ftlb 1/2 drive that will get it off, i can do it by hand if not, got a 4ft 3/4 drive ratchet i haven't gotten to use in a while...
    Flowery Branch
    please do NOT do this as i do not want to read about how you died in the paper
    LOL
    alright well, i had to cut the rubber boot and hammer out the bearings and ****ed my axle a new hole...oh well, it had to be replaced anyways...
    motor is out now...did not come out so easily because the driver side torque mount screw **** hit the chassis and i had to unbolt the entire A/C bracket...
    oh and i did blow torch the nut and impacted it, also broke a breaker bar on it also...IT IS STILL IN THE HUB.
    i had the same problem on both sides when i was putting in my transmission. i just said **** it and pulled out the whole hub assembly on both sides with the axles still in.
    try pb blaster. i had a problem on an eg and use an impact wrench. took it out no prob
    Had the same problem a few weeks ago. We soaked it with PB Blaster first, and after breaking about 5 ratchets or so and trying to heat it up, we bought an impact gun. I know this sounds crazy, but it works; Instead of trying to loosen the nut, try to tighten it, that'll get it to slightly move and then it'll come right off, well at least for us it did
    Newnan
    take assemble apart, like 2-3 bolts lift it out from that bottom joint and take the whole assembly to a shop that has a high impact, i took mine to one and the guy made me look like a dumbass, he set it on the ground got his impact and it came right off first try. and belive me I tried everything you did
    The beach.
    and old mechanic always told me...if it's stuck, tighten it, then loosen it, will never break a bolt.
    and I have a 750ftlb snap on impact, and I've never had any trouble getting axle nuts off, not matter how old they were...your gun was just to weak.
    Quote Originally Posted by TR_Accord
    That's a good last resort, but I suggest he tries what to tighten it first. Trying to tighten it should break it loose and then he can take it right off
    Athens/ATL
    lol dammit I wanted to see if he would try resting the bar on the ground and dumping the clutch!! >_>
    athens
    hey man just so you know, you can really screw up your torque rench that way. by using it to loosen things that tight. get a breaker bar.
    or what ive done. get a long pipe and put the handle of the tool in it, then you have a lott more leverage when you push down. hope this helps.
    yeah i just cut off the rubber boot and broke the axle in two pieces and pulled the engine out, im going to take off the assembly and take it to my friends shop
    Middle, Ga
    Well, glad to see what I'm going to have to go threw within the next day or two....... I have to do a motor swap in my prelude...........
    "Damn, Its Tyler"
    RaceReadyDevelopments
    well i was really really surprised on how easy a honda swap was right up until the axle nut and shift linkage , other than that its extremely simple
    Your sissy bar is only has strong as the weakest link its attached too. 1/2" or 3/4" breaker bar?
    I went to Harbor Freight and got a 3/4" x 25" breaker bar for $15-20 but they didn't have a 3/4" 32mm socket so used a 32mm 1/2" drive with a 3/4" to 1/2" adapter. I think the total cost was $30-35.
    Thoroughly soak with PB Blaster and slip a steel jack handle over the 3/4" breaker bar...I guarantee you it will come right off.
