Results 41 to 53 of 53
Thread: WTF AXLE NUT
    Nov 2003
    Your sissy bar is only has strong as the weakest link its attached too. 1/2" or 3/4" breaker bar?
    I went to Harbor Freight and got a 3/4" x 25" breaker bar for $15-20 but they didn't have a 3/4" 32mm socket so used a 32mm 1/2" drive with a 3/4" to 1/2" adapter. I think the total cost was $30-35.
    Thoroughly soak with PB Blaster and slip a steel jack handle over the 3/4" breaker bar...I guarantee you it will come right off.
    i broke a breaker bar that way,and it had no adapter
    Nov 2003
    Quote Originally Posted by Benefit
    What size breaker bar?
    Senior Member khaxnguyen's Avatar
    clayton county
    LOL!!! *ignoring other posts too lazy to read** my friend and i went thru the same situation on my car lol! broke 2, or was it 3 breaker bars, 2-3 ratchets.. lol tried everything but then gave up and used Snap-On impact. haha that stressed me OUT. SO USE AN IMPACT! their technology is AWESOME
    oh oh we had used a BIG 6 foot pole for more leverage. lol that's how we snapped them all GL
    I give out reps....
    Newbie Photodude RBS's Avatar
    All Over U S A
    grind it off, if your scared drive to me and ill cut it off... just be sure to have an extra axle cause imma f*** the threads on your current axle
    cant drive on one axle...
    All Over U S A
    well borrow someones grinder or rent one from a store... its fairly simple just keep cutting the nut till it comes off LoL, just dont cut the rotor or hub or anything of that nature. i had to do this to khaxnguyens accord once and it worked perfectly
    clayton county
    Quote Originally Posted by 1siccEJ2
    i forgot alll about that little incident. lol yeah it works great. there were alot of sparks!
    I give out reps....
    DUH-KYOO-LUHHH
    Quote Originally Posted by khaxnguyen
    there usually is lot of sparks when somebody is grinding...
    NITROUS JUNKIE
    home
    try tighting it with the gun and then loose it..that worked for me
    just a lil SOHC... B_Hoov's Avatar
    Flowery Branch
    is it off yet? if not i will bring my air compressor, 32mm socket and bad ars impact and do this for you tomorrow.
    Certified Gearhead vtec93accord's Avatar
    One time i had this problem on my hatch. I have a Ingersoll Rand Titanium impact and it has some serious torque to take stuff loose and such. I had to turn the line pressure up on the compressor all they way up to 125psi and it broke it loose then. Try bumping the line pressure up on the air compressor if you can find one.
    Vuong's Garage Vuongy_Dong's Avatar
    Duluth, G-nett
    i broke my snap on 1/2 3ft breaker bar trying to take out one of my customers axle nut. i ended up using an impact tighten it, loosing it, tighten it.........................10 minutes later it slowly came off.
