Results 1 to 14 of 14
Thread: CRX guys I need to pick you brain
    Senior Member mikesEK's Avatar
    over yonder
    Default CRX guys I need to pick you brain
    I'm in the market for a CRX and was wondering does
    it really matter what model or year I get are some more desireable than
    others ,,only thing that comes to mind ((to me anyway)) is seems like thee newest 1991 would be better and I would assum I also want the si model
    right...wrong???? point me in the right direction ...thanks gus
    and OHHH YEAH ...I will be doing a b16 with cable tranny swap
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    i have heard talk that the rear suspension on the '88 Si is more desirable due to being a similar design to the ITR.
    Who knows?
    SOUTHSIDE
    88 si is the lightest si crx...unless you dont want a sunroof, plus your doing a b16 so the si is eazier to wire up than an hf
    Suffolk, VA
    HF is still MPFI whereas the DX is the pain it the ass.
    forgot to add that the 90-91 has those gay ass in door seatbelts.
    Who knows?
    i got a friend selling his crx it needs a new hood all hes wanting is 600 but it is....... automatic
    over yonder
    how much , is the body straight??
    Quote Originally Posted by bouncy!
    PawnShopMike
    Quote Originally Posted by wrekonize
    NOT true, you are wrong on nearly all points. 88 HF Crx is the lightest, and already has mpfi. Its the same job to wire as an SI except HF has EGR stock.
    correct on what you said, last i checked a DX and HF were the same as for body weight. also dont forget if using a HF, you have to switch out the rotor spines and hubs with si or DA's in order for the use of DA axels.
    over yonder
    no dought...I"m glad I made this thread ...very informative!!! now let me get this right the si is the only one with the sir/da hubs???
    Quote Originally Posted by Uptown401
    PawnShopMike
    Senior Member kaotickaozpunk's Avatar
    1991 ftw..believe me you dont really want an 88..they dont have as much suspension pieces for the 88 because of the rear fork..
    DA SQUAD # 13
    SOUTHSIDE
    the dude asked what crx is the lightest and he also mentioned he wanted it to be an si model the 88 si is the lightest si model crx i know the dx and hf are lighter but hes looking for an si...maybe you should read his post more carefully
    It's all about JDM.
    CA to GA
    get a 91 HF model then swap the motor...make sure you upgrade the suspension (eg: control arms, shocks, springs, bushings, etc..), the '91 HF models are better looking and light. the corner lights on the 1991's are way better lookin than the older crx's in my opinion.
    khmer empire foo!!
    kampuchea
    get a 90-91 rex si, a little more weight shouldn't matter. u just swaping a b16. rear diskm sunroof,clean.imo
    version 2.0 vtaaaak
    over yonder
    they all have rear disk,,,,right....I'm learning as I go
    Quote Originally Posted by b18cEG
    PawnShopMike
