Thread: How do you swap a 2JZGTE into an SC400?
    Default How do you swap a 2JZGTE into an SC400?
    Just kidding
    This SC400 is getting a swap from a 2JZ Aristo and is staying automatic. First I just cleaned up the engine bay and removed all the junk in my way, and taped off the intake and turbo ports:
    Then I installed the plug and play harness. I decided to use heat-reflective wrap to protect it where it goes between the firewall and the engine:
    Heheh thanks for the comments guys
    Took the intake manifold all apart and cleaned everything. I thought taking the electronics off would be a good idea before giving the manifold a bath in the parts washer
    Cleaned up and put back together:
    Installed. Also built a custom bracket to hold the power steering resevoir in place here.
    When the car came to me the hydraulic fan for the SC400 was missing, and he wanted to use the Aristo hydralic fan. Since the housing didn't quite line up to the SC400 radiator, I had to weld up some custom brackets. Cleaned up the shroud a bit too.
    Custom p/s line:
    Custom fuel line:
    The oil return lines were damaged when the car came in, so I made a new one:
    Mocking up the intercooler piping:
    Started it up! Just need to finish up a few things before it's ready to hit the road.
    Photography & Design
    Wow, it fits nicely! Good work and reps!
    NIKON Squad | D90
    roflcopter V-Spec II
    Norcross
    Nice work, plain but straight forward write up. Reps.
    Thanks!
    -Doc
    the old man NAIZBST's Avatar
    very nice
    you want to put a turbo in my car?!?!?!
    Sure, bring it on over
    -Doc
