Results 1 to 13 of 13
Thread: Hard wiring Sirius unit
    Senior Member jfman's Avatar
    Default Hard wiring Sirius unit
    How should I go about hard wiring my sirius tuner into my truck so that it turns on when I turn the car on?
    emartu
    Lawrenceville, GA
    i guess you could go off the head unit...or depending on what kinda truck it is, maybe the cigarette lighter???
    Well I dont really want to splice into the head unit's power supply but I will do it if I have to.
    I have once seen a device that was a relay that you could plug into one of the empty fuse location in the fuse box and then you could wire up whatever you wanted to it. Do you know what this is called?
    ATH GA. SRCRX's Avatar
    On the drum set!!
    You can tap into the cig. plug for power!
    (Do not cut the plug that came w/ the unit!!)
    Just wire in a 2nd. cig. plug!
    02 WRX patrick4588's Avatar
    warner robins
    make sure to use a cig. plug adapter back there. if you put the power wire for the sirius unit straight into any 12v source it will fry. they only take 5volts!!!
    GCO Member
    NRA Member
    ok got you guyz!
    Bay Monkey ShadyStyle's Avatar
    Sugar Hill
    We do them all the time at the shop. Your best bet is to splice into the accessory wire at the radio or ignition, as well as ground. Either get a female adapter for the plug to solder it in, or solder to the plug itself.
    warner robins
    i splice in at the radio and use a female adapter.
    GCO Member
    NRA Member
    I own a FrankenCivic GhostRida187's Avatar
    atl
    Gimme a call dude and Ill hook it up for ya if ya need it.
    boosted hatch
    Its a pain
    atl
    Quote Originally Posted by cadcivic
    Its a pain
    Its harder to wire a new amp with RCA's then wiring up a Sirius. Can be done at most in an hour easy.
    co-lame-bus
    Quote Originally Posted by ShadyStyle
    x2
    95 del solp 3.5@utoGrip's Avatar
    wat i do is splice the wire, plug the + into the audio fuse in the fuse box, and put the - under some screw behind the fuse box
