Results 1 to 23 of 23
Thread: WHICH IS BETTER???
    marietta,ga USA
    Default WHICH IS BETTER???
    i wanna boost my car but the thing is which would b better 2 boost a b20 with a gsr head or a ls with a gsr head??? which would b better
    NAwasBEST NAG2I's Avatar
    metro
    if you have both then b20
    ATL_DA_Squad #3
    STREET<3LOVE
    i'm a got dang wallaby!!
    neither... both are hondas..... i mean why? lol lol i kid i kid i'm drunk and don't know hondas.. don't ask me lol
    02 WRX patrick4588's Avatar
    warner robins
    how about a straight ls
    GCO Member
    NRA Member
    Sep 2003
    woodstock, ga
    LSVtec
    wow.... some useless info here.... I do know this , i would do the LS... The b20 has MUCH more thin sleeves.... Drop a set of forged piston's and rods in and your good to go for 400whp on a ls.. The sleeves in b20's will blow out a lot sooner tha a LS.. I also think the b18b head flows better , but dont quote me on that...
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    warner robins
    Quote Originally Posted by Goinfasterthanu
    even with the forged internals, you will probably need some head work to reach 400whp. you can probably get it, but it will be A LOT easier with a good valve job and p&p. yes the b20 has thinner sleeves so the ls is better for boost. good post goinfasterthanu
    GCO Member
    NRA Member
    Don Mon SiRed94's Avatar
    Morrow 30260
    if you are keeping stock internals use the b20 bottom end... if you are going forged pistons, rods etc i would use the ls bottom end if you aren't going to get it sleeved....
    Thanks ... belive i learned all this in 2 weeks..? I was a h22 guy..... Yea head work would help a LOT as the ls/b20 head flows like ass.....for 400whp that is...
    2009 zx10R
    2005 919
    YEAH! bRiAnMcIvIcS's Avatar
    LS block with a GSR head. B20=weak cylinder sleeves. If you want a 2 liter than just resleeve the LS block to make it a 2 liter, 84.5mm or whatever. I heard that 83mm sleeves are more ideal for turbo, i dunno though.
    metro
    hmm i didnt know b20 sleeves werent as strong as an ls
    learn somethin new everyday i guess
    but if thats the case then ya go ls
    ATL_DA_Squad #3
    STREET<3LOVE
    marietta,ga USA
    so best bet is 2 go wit a ls bottom end wit a gsr head damn i thought it woulda been better if i was 2 go with the b20 considering it had more torque than the ls but didin know about the sleevez but would it matter if im goin with a gsr head cause i do plan on upgradin the pistonz n etc.
    140 on one wheel
    columbus, ga
    Trader! H22 FTW!...lol i cant say anything though. I gave up on my h2b setup and bought a 240
    i would just boost the stock ls if i done ls vtec i would do all motor gl
    warner robins
    gsr head and b16 head flow nearly identical in stock form.
    GCO Member
    NRA Member
    ATL, GA
    Quote Originally Posted by jdm4life
    I thought the point to do ls vtec is to have a stronger bottom end to turbo with vtec... Why not all alum. block and head to do all motor?
    TheMyth
    Wrong killa. gsr head flows more than the itr/b16 heads.
    Yep....I got nothin Pickleteg's Avatar
    Clarksville, TN
    I always thought that the B16/ITR head flowed better than the GSR head....maybe I am wrong.
    95 Teg SE Synapse A/C ramhorn kit, 276whp, 210wtq
    09 Si Sedan...some bolts ons....
    ATL, GA
    I thought that ITR head has some port job on them, which suppose to make it flows better too...
    warner robins
    Quote Originally Posted by Berta
    nope. in stock form, the b16 and gsr head flows within 2 cfm's of each other. alaniz did the test a few years ago. i used to have the chart. but 2 cfm's doesnt mean **** honestly. they are about the same. the gsr has slightly higher compression due to the smaller combustion chambers. the itr is a b16 head with a port job and will outflow either in stock form.
    GCO Member
    NRA Member
    TheMyth
    haha i still have to disagree with you. I've had them all. I know the differences. And i'll like to see you explain your idea to Ed @ Balance too.
    JDM TYTE AnthonyF's Avatar
    The Carbon Fibered R6
