Results 1 to 15 of 15
Thread: battery keeps dying after cutting car off for awhile
    Senior Member Nang's Avatar
    Default battery keeps dying after cutting car off for awhile
    this started happening recently, the car would drive fine, but when you come to a stop the cluster gets dim and sometime the battery light would flash for a moment real quick. after i finish driving, park the car and come back out to start it, theres not enough power and then the battery dies.started the car, and left it to turn and pulled out the (-) off the battery terminal and the car stays on
    checked all the fuses, any specific one>
    car will crank when jumped start
    last mods:
    swap
    change alternator
    swapped 92 civic
    Needs a New battery an might need a new alternator, most likely it will need Alternator remmeber the pulling of the neg post was a OLD school trick for OLD school cars, now the computer controls,an would keep the car running...charge battery to 12 volts, then crank it up an put a volt meter on it, if it is not near 13.5 -16.volts its bad! REPS please
    if its not charging, then check to see if your alternator plug has ground an power, an the power wire single that bolts a 10mm nut has constent power also
    if all that checks out fine, but not charging replace alternator
    battery and alt.
    Henry Co.
    dont ask for reps.
    volt test the alternator and battery, possibly take both to an autozone or something like that, they have free tests.
    Gotcha! You can thank Pansy Loves S-13 for posting that got my attention o this thread. But she is right. Never ask for, expect or demand reps. Later, QD.
    Drive to the nearest auto parts store & ask them to test the alternator & battery, it'll narrow it down a little. They'll tell if your alternator isn't putting out enough and/or your battery is bad.
    if you test and they say your alternator is good and your battery is good, check your battery terminals
    Straight up JDM!
    Buy a damn new remanufactured alternator from any local autoparts store and a new battery...and your problems will be solved.
    Be Vivid magneto198's Avatar
    ATL/lenox/Lville
    sounds like a dead battery that wont keep a charge
    Turbo-Wired
    East Cobb
    Quote Originally Posted by magneto198
    Agreed. Bad alternator wouldn't let the car keep running if the battery was dead, and a working Alternator but bad battery explains why everything works fine while moving at speed but dims when you slow down. Also explains why the car jumps fine but won't start on it's own. You may have a perfectly good battery too and you're experiencing a heavy parasitic battery drain from a short. Might wanna check on whether there's juice flowing from the battery with the car turned off.
    You listed that you changed the Alternator. Is the tension on the belt tight enough because if not then the belt slips and it will not charge the battery. Telltale sign is a squeling from the belt. I remember my first car was the same way. The guy tightening my belt did not put enough tension on the belt and it slipped on the Alternator pulley and would not charge the battery.
    Clean the battery terminals, check the connectors on the alternator, then have both the alternator and battery tested at Autozone...
    ap2 lbp s2k
    Hampton
    sounds like everyone has this one pretty much figured out, on to the next question lol
