Results 1 to 25 of 25
Thread: carbon fiber???
    boosted-eclipse
    Default carbon fiber???
    ok so im not sure if this is the right area to post this but ill throw it out there anyway?.... so my question is my carbon fiber hood is starting to show a little oxidation..how do i go about fixing it?? is there some sort of polish i need to use or anything?? if someone has any tips that will be awesome!!@ thanks
    Out the game again!!
    southside of the border
    get it coated it again
    Soon!!
    aka Honda_Chick
    Winderrr Ga
    wet sand and buff it =] shines like new!!
    boosted-eclipse
    what should i use when i buff it??? and what git sand paper like 500??
    Quote Originally Posted by honda_chick
    Weekly Gwinnett/Junciton Meet
    Quote Originally Posted by andrewz21
    LOL more like 1500 or 2000 grit. Use 600 grit if you are gonna get it resprayed.
    Macon
    Quote Originally Posted by UpSideDownDesi
    ^^^ I agree. Thats the easiest and cheapest way to do it. The BEST way to do it is to have it resprayed.
    Land Rover LR3 HSE
    boosted-eclipse
    awesome thanks dude ohh by the way nice ride...do yall know of anyone that could respray it by anychance???
    Quote Originally Posted by allmotoronly
    boosted-eclipse
    so pretty much there is no polish i should use??? nore wax??? im sry if i sound like a complete retard ..lol this is my first car that had a cf hood ...i just herd to never wax it?
    blank
    nowhere
    it wont buff out more than likely every hood i have resprayed has to have all the old clear removed for it to become clear again. i charge 150 to reclear carbon hoods. old clear gets stripped and then recoated with good clear that should last alot longer if taken car of
    DBlock
    tha ville
    Bring it to bucky!!!!!!!................1
    boosted-eclipse
    yeah thanks dude where are you located??? and how long dose it typicaly take bc i dont have an other hood to ride with in the mean time ya know...lol
    boosted-eclipse
    ohh an other thing if i were to buff it out what would i use as you can see its not bad yet im just tring to get to it befor it gets bad ya feel me?
    Attached Thumbnails Attached Thumbnails -blk-civic-jpg
    blank
    nowhere
    i am near the mall of ga right now. and from the looks of that pic its to far gone.
    boosted-eclipse
    ok well i got your number i guess on here mabe in a few weeks i can get with ya..i just need a temp hood till this one is finished..dude i think i know you from somewhere too??? you use to stay in conyers by any chance???
    blank
    nowhere
    yea i did a few yrs ago had a red neon. i can do the hood in a day just to let you know
    It's an epoxy resin, nothing like a traditional clear coat sprayed over paint and it's not there to protect anything...it's what makes the hood a solid and not just a piece of cloth (carbon fiber) blowing in the wind.
    If it's just slight "oxidation" then you can use rubbing compound or a really fine grit sandpaper, a polish, then a wax...simply research a how-to on "wetsanding".
    If it's discolored or really bad then you should repair the epoxy. A spray bottle of acetone misted on it may smooth out and dissolve the "oxidation" and imperfections or it may need to be sanded down, sprayed with acetone, then the epoxy resin reapplied. It sounds difficult but it is relatively easy to do. I'd never just spray a clear coat over it, the discoloration is normally from heat and is all the way through the resin, not just the surface...spraying a clear over that doesn't fix anything PLUS clear coat is no where near as flexible as resin...it will crack with the slightest impact or flexing of the hood.
    blank
    nowhere
    It's an epoxy resin, nothing like a traditional clear coat sprayed over paint.
    but in fact it does have a form of clear on them. i have sanded them off a few times.. it might not be the same clear but its not resin. the way it oxidizes it cant be anything quality
    Some of them do have a clear sprayed on, seen it advertised on hoods made the last few years but why? The epoxy resin is more than capable of being polished and waxed and can stand up to weather as well as anything else. If anything should be applied over the epoxy I say a UV resistant clear gel coat
    Mad Scientist xb1's Avatar
    Athens, Ga
    The gelcoat the speedminded is talking about is sprayed on just like regular auto paint, but its between 2x and 3x as thick, and requires special sprayers designed for gelcoat. Usually a CF part is made with either epoxy resin (more flex, turns yellow in UV light) or a polyester vinyl resin (brittle, no yellowing but can cloud). I usually use a surfboard gelcoat for my final clear coat which needs an extra sanding aid added, but I know that better ones are out there. If all you care about is having the CF look rather than actual weight savings, then any polyester clear resin/gel will more or less work. If you have an epoxy only CF part, then you shouldn't care if yellows or not, as it was designed for weight saving purposes and not to look pretty. Sadly, with out getting very expensive, there is no real middle ground.
    Dunwoody
    so you traded the eclipse for the civic whats it got in it man definitely looks good though better than the eclipse
    ek hatch
    Macon
    recleared my carbon hood and came out really good,but eventually the sun baked the clear back into previous cracks, so if it has any small cracks its probably gonna take a good couple coats
    97ek hatch
    both jason (speedminded) and mike (buky) are correct on their part. My CF hood on GSR was foooked...took my time wet sanding it down with a 400 grit few times and i was able to sand the fade out (it didn't go all they way down)....remember i used 400 grit because i was gonna get my hood recleared. No way you'll be able to dig down the oxidation with 1500-2000 grit....that will only take care of surface/minor fade. Now my hood looks good as new with just 1 coat of clear. If you wanan save money for now and only have minor fades on the hood then go ahead and wet sand it, but if you want 1 time done deal....get it recleared.
    boosted-eclipse
    dude i knew i knew you from somewhere!!! threw joel and from chillies i worked there with u and your girl..lol small world
    boosted-eclipse
    thanks dude its honestly not that bad some people dont notic it but i do i may try to wed sand it and see where im at with that..if not buky ill be seeing you soon!! ..lol..so after wet sanding it what can i polish it with?? any normal car polish will work?? and same with the wax??
    boosted-eclipse
    yeah im actually starting to enjoy the civic its a lil slower than the eclipse but its cool..its great on gas..lol..it only has a ls swap so its pretty quick for what it is..now im debating on turboing it??? i have a turbo at the house just need all the other crap ya know..more than likly it will remain a gas saver till i get back from fl??
