View Poll Results: How are you controlling your boost?
Voters
54. You may not vote on this poll
  • Manual Boost Controller
    13 24.07%
  • Electronic Boost controler (AVCR or others)
    23 42.59%
  • Controlled by factory ECU
    8 14.81%
  • No boost control.
    10 18.52%
Results 1 to 40 of 50
Thread: How are you controlling your boost?
    Flowery Branch, GA
    Default How are you controlling your boost?
    Just wanted to see what people were using for boost control.
    wastegate
    wastegate
    You have boost??
    Hampton, Ga
    ADVD or AVHS or ACASSETTE
    sorry i have no boost
    Toyota Tech
    Dec 2003
    Claxton, GA
    greddy profec ebc
    banned from heaven..
    Im using a Cobb AccessPORT(EM). Which sets my boost right at 16.5psi. No need for a boost controller for me, so which means im using an electronic boost controler (AVCR or others).
    Hampton, Ga
    Quote Originally Posted by Maniac
    step your game up that went out of style in 93
    Quote Originally Posted by Wurm
    Well to tell you the truth I don't know where my "boost controller" would fall under. I mean I am using my stock ECU. Which means im using my stock Ecu as a boost controller. Lol plus I have an 06, im pretty sure im not using anything that was used back in 93. Come on man, the hell?
    Flowery Branch, GA
    The ap is still using the ECU to control your boost. It just modifies your parameters in the ECU.
    Hampton, Ga
    i was just making fun of the name AVCR sorry
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    Completely adjustable in the ecu
    2011 Camero - Fast
    1998 T/A - Slow
    BOOST Gets U LAID
    Cedartown
    Im loving my AEM Tru-Boost. Adjustable to 30 with stock sensor and with aftermarket sensor to 75psi.. Use Friendly and alot of functions. Boost Alarm, Scramble boost. Boost Setting A and B.Very nice for the price
    manual for now (bleeder valve), electronic (profec b spec 2) when i change my setup using an external wastegate.
    i've tuned a couple cars using the aem trueboost and actually like it. it's pretty user friendly once you work your way through the manual. like most boost controllers the manuals suck!!
    140 on one wheel
    columbus, ga
    waste gate 4-5lbs creeps to 7 on cold night on top end. I sold my boost controller so id have extra money.
    i'm a got dang wallaby!!
    internal wastegate ftw
    NICK'S AUTO REPAIR esiatlanta's Avatar
    sugarhill
    wastegate......
    'Round These Parts
    i can't even answer this question anymore
    It no longer applies
    Leisa and S. 4 Life NM?
    Resident Isuzu Owner Lusos's Avatar
    Barnesville, Georgia
    I'm running the stock ECU. But with how it fluctuates, sometimes I can be pushing up to ~9psi at a factory tuned ~7psi. Oh well, I guess 1988 is a long way from today.
    I plan on using one of those EBay boost controllers for a little while. It can't hurt, I've got another car to drive and another motor waiting on the stand as it is. TURN UP DA BOOST!!11!!111!
    "Silkie Johnson is nominated [Player Hater of the Year], for calling in a bomb threat... To the Special Olympics"
    Privateer Racing!!
    Duluth,Ga
    We run the Innovative boost controller, Its the easiest on the market to set up.
    Basically u set up each stage, You have a total of 6 stages, Launch and 1-5
    too setup the stages you just go too the stage you want and you hit the desired boost for that gear.
    Each time you push the clutch in while racing it will go thru all 5 stages.
    Or you can get the s300 and use the boostcontroller option, all you ahve to do is add a boost solenoied,and then play with the percentages, but you have to do at the track or on the dyno.
    Yep....I got nothin Pickleteg's Avatar
    Clarksville, TN
    I control mine with pulley size!
    95 Teg SE Synapse A/C ramhorn kit, 276whp, 210wtq
    09 Si Sedan...some bolts ons....
    JDM TYTE AnthonyF's Avatar
    ^^ me too. i'm at 15psi with some belt slippage
    The Carbon Fibered R6
    one day soon electronically but right now NA
    middle ga
    greddy profec b spec II
    $25 pressure regulator, air control solenoid, and a button on my shift knob
    Not blowin up now MattB's Avatar
    Columbus, Ga
    greddy emanage and the profec setup.
    02 WRX patrick4588's Avatar
    warner robins
    just the wastegate. my wastegate is also a boost controller tho...
    GCO Member
    NRA Member
    Senior Member 95alty's Avatar
    Manual Boost Controller...
    PIC TOO BIG
    I control it with my mind.
    - IA Mgmt
    raggedy volvo owner
    adapted a saab boost controller to my car for a bit with solenoid. that worked well for awhile, but then went to a larger turbo and wanted more accuracy.
    Manual boost controllers work well, but lack flexibility.
    Went with a manumatic boost controller for awhile, that consisted of a pair of solenoids wired to a toggle switch in the cabin hooked up to a pair of MBCs in series. With both solenoids closed, the car works purely off the wastegate giving a stock boost of 7psi. When you open the first solenoid, boost diverts into the primary MBC, raising pressure to 13psi. Open the second solenoid and boost routs again through a second MBC set to 18psi. That worked for awhile, but was rather bulky and sometimes tempermental.
    Finally working on using the standalone to manage boost. it allows for boost based on throttle input, gain control etc. As soon as the wastegate is all plumbed, I'll wire that in.
    My car is factory....
    Every single performance part and or modification it has was made in a factory somewhere.
    open wastegate and let the good times roll
    Greddy Profec B Spec II
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    I made my own MBC...
    Flowery Branch, GA
    Quote Originally Posted by a98tegLS
    how do you like that Greddy unit? I am selling an Apexi AVC-R right now to help pay property taxes on the house, but I plan on buying another one sometime after the first of the year. Will probably go with another AVC-R, but had thought of the Greddy also.
    Toyota Tech
    Dec 2003
    Claxton, GA
    greddy rocks, never had no issues of creep/leak/problems. takes a moment to figure it out, lol my directions were all jdm
    warner robins
    it all depends what you are going to use it for. i personally have no use to change boost levels inside the cabin. the only times i change it is when i go to the track. since my wastegate is a boost controller too, all i have to do is change vacuum ports and changes my boost level. it literally takes 5 seconds to go from 15 psi to 22psi. for those who street race a lot and need to up the boost on the fly, and ebc is ideal
    GCO Member
    NRA Member
    Quote Originally Posted by crashtke
    No complaints, here.
    "Cool car" less.
    Flowery Branch, GA
    Quote Originally Posted by Benefit
    Ya open the wastegate and all the exhaust bypasses the turbo and no more boost, lol.
    warner robins
    running open wastegate means he has no dumptube. doesnt really make sense in this post, but it doesnt mean the wastegate is open all the time
    GCO Member
    NRA Member
    superduper LLLLLLLLL
    EBC!
    Greddy PROFEC II
