Results 1 to 5 of 5
Thread: Need help on swap!
    Arrow Need help on swap!
    Ok im taking out the old and bringing the new... To start I have a 93 civic cx hatch and im going to put in a 99 civic EX SOHC VTEC engine in there. NOW what would I need to do to make this car run right... what to I need as far as wiring and such. Any help would be great.
    __________________
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    OBD2 ECU, an OBD1 to OBD2 jumper harness for your ECU, rewire your distributor plug, wire up knock sensors, I think the SOHCs had the 4-wire O2 sensors, as well, so you need to change over to that....ummm...that's all I can think of off the top of my head, but I'm sure there's more.
    Senior Member Nang's Avatar
    or you can use a
    p28 and skip knock because a p28 doesnt have it
    your harness and add vtec pressure switch and the solenoid
    convert to 4wire
    unpin and repin your old dizzy with the new one. obd1 has 2 plugs while obd2 is one, same colors either way
    Quote Originally Posted by Nang
    or you can use a
    convert to 4wire
    Thanks....
    cravin a s2k
    Cookeville, Tennessee, United States
    simple swap. NANG pretty much hit it on the head.
