Thread: HEAD GASKET REPLACEMENT B-series Vtec
    GoonSquadsNinja JDMjoe's Avatar
    i85north
    Default HEAD GASKET REPLACEMENT B-series Vtec
    I need to know how hard and how expensive it is to replace!!! thanks
    Is not a male
    South southside.
    I had a friend do mine for me, i have a SOHC and all the stuff to do it from Honda was like, $120 maybe, including oil and everything then its like $80 to have the head presure checked and milled. It's not hard, I watched/helped and the hardest part was keeping the rocker arms together when it was apart and then setting timing so its not bad at all. If you go to a shop its like 600+ usually.
    i85north
    Quote Originally Posted by hondaracecar
    Thanks man, im hoping its nothing more than that!
    i85north
    Anybody????
    Low-n-Slow iEvo's Avatar
    Gnett
    just take ur time and dont lose anything. ull be fine
    i85north
    Its not my car, i was thinking about buying it but honestly after talking to some folks i think its the front main seal!
    RISKY RISKYB's Avatar
    athens
    its cheaper to do it yourself, not hard just time consuming to do it right
