Thread: My rear brakes LOCK UP....
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Exclamation My rear brakes LOCK UP....
    and i really dont know why. I'm thinking they might need to be re-adjusted, but im not sure... Why do they lock up?? how can i get them repaired or adjusted? How much should it cost???
    They only lock up if you step on the brakes too hard, or too abruptly. If you're careful, and light with your toe on them, they work just fine though.
    \\\ATLANTA~ATNALTA///
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    drums or discs?
    Banned SE-Rious1's Avatar
    WINDER,GA
    ABS ?
    San antonio 210
    Quote Originally Posted by SLYDWAYS240
    ABS ?
    thats what i was thinking
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    i used to have an old truck and had the same problem. for me the master cylinder was going bad and i had a bunch of shit in the brake lines. try bleeding the brakes before you buy anything new, if need be bleed the brakes out completely put all new brake fluid in, see how that works. if it doesn't help replace the master cylinder. or better yet take it to a brake specialist and get them to see whats wrong, maybe 15-30 bucks. and fix it yourself. good luck
    Stockbridge foo
    if its drums the wheel cylinder will def. cause that
    Jason..
    RISKY RISKYB's Avatar
    athens
    if its disks, maybe sticking calipers but doubtful both at the same time, unless the pads and rotors have so much wear the pistons have extended too far
    Jan 2003
    Quote Originally Posted by madking411
    sounds like they're working fine if your car is non ABS, although the rears shouldn't lock up first.
