Results 1 to 23 of 23
Thread: Disc Brake Swap from 97 LS to 96 EK coupe, few questions.
    Your Moms Moderattor
    pleasant hill
    Default Disc Brake Swap from 97 LS to 96 EK coupe, few questions.
    Ok I know that if do a suspension and brake conversion on my 96 EK coupe from my Integra I have to change this one part, I do not know what its called but it looks like a brake fluid hub, its right there on the firewall left and down from the master cylinder.
    Here is the situation, the civic "hub" has 5 brake line connection while the integra has only 4 and they are also shaped diffrently.
    If I want to properly utilize the four wheel disc brake swap I know I need to change that one part.
    But since these two hubs are not compatible, where do I get the right one?
    I am thinking I need the fluid 'hub' from a 99-00 Si, but I am not sure.
    does the Si have four wheel disc brakes? And is that hubed shaped the same as it would be on a 96 ex coupe?
    Ok so I found out that that thing is called "proportioning valve"
    so which one do I need to get to make my disc brake conversion operate at optimal capacity?
