Results 1 to 23 of 23
Thread: Disc Brake Swap from 97 LS to 96 EK coupe, few questions.
    Your Moms Moderattor
    pleasant hill
    Default Disc Brake Swap from 97 LS to 96 EK coupe, few questions.
    Ok I know that if do a suspension and brake conversion on my 96 EK coupe from my Integra I have to change this one part, I do not know what its called but it looks like a brake fluid hub, its right there on the firewall left and down from the master cylinder.
    Here is the situation, the civic "hub" has 5 brake line connection while the integra has only 4 and they are also shaped diffrently.
    If I want to properly utilize the four wheel disc brake swap I know I need to change that one part.
    But since these two hubs are not compatible, where do I get the right one?
    I am thinking I need the fluid 'hub' from a 99-00 Si, but I am not sure.
    does the Si have four wheel disc brakes? And is that hubed shaped the same as it would be on a 96 ex coupe?
    Ok so I found out that that thing is called "proportioning valve"
    so which one do I need to get to make my disc brake conversion operate at optimal capacity?
    warner robins
    you dont have to use and integra proportioning valve. i did a rear disc conversion on my civic and didnt use one and the brakes work just fine
    JJSPEC.COM
    pleasant hill
    I have felt the braking difference between a swaped civic and say an integra, its not the same.
    To get the full advantage you need to have the right amount of pressure in your brake lines.
    some people tell me you have to change the mastery cylinder along with the brake booster others tell me you just have to change the proportioning valve.
    Smyrna
    You don't have to change anything with the stock brake system. I did the rear disk conversion about a month ago and didn't change anything on the brake system.
    98 EJ8 - Stolen ( Thieves)
    pleasant hill
    now are you sure you using your disc bake swap to its full potential?
    Smyrna
    Quote Originally Posted by theprofiteer
    100%
    Just be sure to put the shims on the pads. I forgot to do it when I initially converted the brakes and it definitely showed that the pads were only touching the disc slightly. Once I installed the shims, the pads were making contact with the disc perfectly.
    I have noticed a substanial (sp?) increase in braking. My stopping distance has decreased dramtically.
    Hwy 315
    Quote Originally Posted by bafbrian
    100%
    I have noticed a substantial (sp?) increase in braking. My stopping distance has decreased dramatically.
    And it'll improve some more when you try changing out the proportioning valve... you'll be impressed with the difference that is made when your rear brakes are actually fully engaged.
    I've performed this conversion on many civics, the first one was without the proper valve; and i changed it out on a bet with my friend one day...
    ...i lost the bet
    we did a before and after test by slamming on the brakes @ 40mph and drawing a chalk line at the front tire. The proportioning valve decreased the distance by 8.5ft @ 40mph.
    But suit yourself
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    pleasant hill
    cool, do I just need to change the proportioning valve, or the master cylinder too? If its just the P-valve, and I have a 96 ex, I have to use one from an si right?
    warner robins
    my car stops so yes
    JJSPEC.COM
    ATH GA. SRCRX's Avatar
    On the drum set!!
    I have the same set up, I Just have not put them on, does anything have to change
    W/E-brake cables??
    Smyrna
    You are gonna use the use the e-brake cable from the discs. It should all be one intertwined setup.
    The e-brake cable will be a bitch to undo and then reconnect. Everything bolts up perfectly bcuz of Honda and Acura being very interchangeable.
    On the drum set!!
    Damm I'm not sure if I was given the calbes from the Discs??
    Smyrna
    Quote Originally Posted by SRCRX
    They should a part of the brake system. Long cables with a "soda can" at the end of them.
    If not, just hit a junkyard and get some from any Integra from 94-01 and they will work.
    On the drum set!!
    Thanks!!
    Plus 1
    Smyrna
    The prop valve on there will do the job just fine. I did this conversion about 2 months ago, it is not necessary to do this.
    pleasant hill
    My 1996 Honda civic EX has a 6valve non-abs proportioning valve.
    I am doing a complete acura integra suspension and brake conversion, whos proportioning valve is the 4vlalve abs-friendly version.
    could some one please tell me ----WHICH---- proportioning valve i am going to need to make the swap worthwhile.
    ITS ALOT of work putting the suspension system on your car in your front yard
    IT is NOT worth it if you do not change the proportioning valve because you will not be getting that significant of a braking power increase.
    So some one PLEASE tell me which proportioning valve should I use if I have a 1996 NON-ABS honda Civic EX
    Hwy 315
    90-93 integra (non abs)
    94-96 integra rs
    [/URL]
    pleasant hill
    reps given
