Thread: d16 build
    vtak yo! E.G. KING's Avatar
    Austell, GA
    Default d16 build
    whats a good setup for a d16 that will be driven daily shooting for 155-160 to the wheels and im possibly wanting spray (not 2 sold on that devilish juice) help?
    CP
    Damn all mota would be nice, but id like to hear phssssss.
    Quote Originally Posted by E.G. KING
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Dual cam Zc pistons, ported and polished head,mild cam, possibly cbr 600 ITB's. Thats a start!!!
    Work in progressneed slicks!
    d16 on low boost (t3 .42/.48, .60/.48, or t25), socketed/chipped ecu, and tuning...you'll hit that easily. i would upgrade the clutch just in case. the stock one should hold, but it doesn't always (just tuned one today that started slipping around 170ish whp/wtq and it wasn't the first one that slipped at that power).
    Don Mon SiRed94's Avatar
    Morrow 30260
    yeah... and as far as the p29 and pm7 pistons go... that's not really a road you want to go down... unless you are getting after-market ones made of a stronger material... I think NPR offers some for around $120... because the ring lands on those pistons will not last very long under the 12:1 compression even when properly tuned... and if you do go the high comp route... please get your shit balanced because if the piston weights do not match the weight of the throws on your crank, the rotors in your oil pump will be trashed and your engine will be destroyed.... however, as Scotty stated 170 HP could easily be had on boost with 6-8 psi and still be a reliable DD... then you wouldn't even have to go internal...
    Proud Mr2 Turbo Owner
    Subherbs
    d16...... you can get a LS/Vtec motor for the low and you can EASILY make 160whp
    I am Montage
    Augusta, GA
    get a greddy kit, run it on 6psi, get it tuned. 160whp easy
    just run 50 shot.
    Subherbs
    Quote Originally Posted by blue_5g_zc
    why would you spend $1000+ on a turbo kit when you can build a motor for less than that and have 160WHP NA, which will murder the turbo car
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    If it's non-vtec, do a minime build, with a decently built head (p&p, valve job, cams, valvetrain) using a z6 or d15b head (P08), bump your compression using aftermarket pistons. I agree with SIred that the ZC pistons will be too high compression for a DD, when I had this setup in my ef, my cylinder pressures were rediculously high. Add a good intake, IM, race header, and a chipped and tuned ECU, you will have a fairly fun a reliable little daily.
    2 Slow 2 Know
    Dec 2003
    Quote Originally Posted by DustnU
    I agree...
    02 WRX patrick4588's Avatar
    warner robins
    boost
