Thread: Quick T3/T4 Question
    Wanna-be-OG
    Newnan
    Default Quick T3/T4 Question
    I'm looking for a line for a T3/T4 that attaches to the top-side of the turbo....I'm sure it's an oil return line, but what I'm asking is, do you have any clue as to if it's the same as per-say a -4an Nitrous line or is it a 1/8 NPT? A friend lives out in the boonies where no shops are and needs one and I'm closest to everything up here so I was hoping I could get a solid answer before I go buy some random shit! Also, does anyone have any for sale or know where I can grab one on the southside besides Summit or something?
    Thanks for the help guys!
    Wanna-be-OG
    Newnan
    lol, I must sound retarded or no one feels like helping.....I'm a nitrous guy so I was going out on a limb trying to figure it out....TTT
    Wanna-be-OG
    Newnan
    wow...is it that serious no one can even answer the question.......
    pictured is your standard T3-T4 oil line kit......
    As you can see the two braided hoses have end fittings similar to nitrous lines which are -4an and one has a totally different fitting! I ONLY need clarification on what type/size fittings those two lines have.....
    so fucking bump again for the almighty IA
    Attached Thumbnails Attached Thumbnails -dsc04337-jpg
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    the thinner high pressure steel braided line is the oil feed line... the thick rubber line and fitting is the return line
    The line on top you're thinking of (if its braided) is the feed line and that hooks up to a little L shaped fitting, and the line goes in end and the other end threads into the center housing of the turbo...
    the return line can use the 4th or 5th fitting from the left, you thread that into the flange part and then bolt up the flange part with a gasket or copper spray in the middle.... then you squeeze up that rubber pipe onto it and clamp it down with a small clamp... make sure its tight.
    drives a trycicle
    newnan
    i'm back online.thanks for trying.
    Wanna-be-OG
    Newnan
    Thanks man! All I was asking for!
    Quote Originally Posted by HomeMade240
    Yea, I tried lol! What can ya expect though....
