Results 1 to 13 of 13
Thread: clutch pressure plate help/ideas/questions
    wherever
    Default clutch pressure plate help/ideas/questions
    Alrighty, i had installed a exedy clutch about a year ago, and recently it started slipping, not cool. So i go to replace my clutch disc today figuring that my daily driving and drifting have worn the disc.
    After finally getting everything out, i discover that the clutch has grooved the pressure plate (and flywheel, but the flywheel surface is repleaceable= no problem).
    But now im on the hunt for a pressure plate for the ACT 4 puck disc, and i have some questions.
    Do i NEED to go with a high pressure plate? Im thinking that because the force of the clutch is only focused on 4 smaller areas that a normal pressure plate would be ok.
    Would the racing beat street/strip work OK with my car being boosted (6 psi JRSC)??
    Does anyone know where to get a replacement p. plate?The only ones i can find are ACT, and they're a bit pricy
    thanks!
    02' Miata
    clutchnet.com
    competitionclutch.com
    they both sell PRESSURE plates but youll have to call Competition to get a price.
    you dont make enough power to run an upgraded PP, just get a strong kevlar UNSPRUNG disk an youll have all the grabbing force you need
    wherever
    thanks mike , but i already have a 4 puck sprung clutch disk. i'm pretty sure that it ll work ok , but i wanted to get some opinions on using a perfomance clutch with a regular pressure plate.
    i emailed competition clutch about a p. plate.
    02' Miata
    thats cool , i prefer unsprung beause i have had bad luck breaking springs.
    but i would run a soft pressure plate, prob make it easier to drive/drift
    wherever
    Really? Even with all the crazy driving i have done has never broken a spring *knocks on wood*
    Well, i wont mind a lighter feeling pedal, as long as it grabs properly, i dont care how the pedal feels.
    Is it possable to machine the face of a p. plate?? Just curious....
    02' Miata
    I've torn the steel where the spring mounts after installing the helical LSD...Clutchmaster Stage III disc with matching pressure plate. The disc was too harsh anyways so I went with an ACT street disc and kept the stage III pressure plate, by far the best setup i've ever driven (for a lightweight "low" power FWD anyways)
    As for the RWD, i know droptopdrifter can adapt to any setup...driveability shouldn't be an issue, he just needs one that will hold up to what he does. I would honestly go with a better disc and stronger pressure plate, why have one that is always going to be stressed and pushed to its limits?
    Quote Originally Posted by DropTopDrifter
    ugh, machining all those fingers...that would be a major pain in the ass!
    wherever
    you know i mean the face that goes up against the clutch disk
    02' Miata
    ohhh, i was thinkin you were wanting to modify the pressure /force itself...lol
    when was this? did anybody ever get back to u?
    wherever
    Quote Originally Posted by CH@Dbee
    i emailed them sat. night, not expecting a reply until sometime today or tomorrow.
    02' Miata
    I'LL MAKE SURE WE CHECK THE EMAIL TODAY.
    wherever
    well i just talked to Chris H. a little while ago and told him i would get someone from CCR to call and order the pressure plate for me.
    02' Miata
