Results 1 to 11 of 11
Thread: 1990 Nissan 240sx Fastback
    Default 1990 Nissan 240sx Fastback
    SOLD!!
    Make: Nissan
    Model: 240sx Fastback
    Year: 1990
    Mileage: 164,xxx
    Engine: KA24E
    VIN#: JN1HS36P5LW119105
    Location: Morrow, GA (10-15 minutes SOUTH of Atlanta, GA)
    (Pic dates are right, but the car still looks the same)
    More pics here: http://neejay.net/phpAlbum/main.php?cmd=album
    Engine
    HotShot Intake
    2.5" Magnaflow Hi-Flo Cat and Resonator
    2.5" Stainless-steel, mandrel bent piping
    Authentic Tanabe Muffler
    300zx (Z32) Fuel Filter and Radiator cap
    Suspension/Brakes/Drivetrain
    Tein Basic Coilovers w/ Tein Camber Plates
    S14 Tie rods
    Rear strut bar
    Energy Suspension Polyurethane Bushings (few)
    PowerTRIX Rear-Upper Control Arms
    JDM 180sx Front brakes
    SPL Stainless-Steel brake lines
    200sx Turbo brake master cylinder (15/16)
    Polyurethane filled motor mounts and transmission mount
    Exterior/Interior/Misc.
    Hella H4 Headlights + Sylvania Silverstar bulbs
    JDM Nissan Clear/Amber Bumper signals
    JDM 180sx Nissan humped sidemarkers
    S14 Manual Seatbelt Conversion
    Gutted behind front seats
    I just installed the rear SS brake lines, new pad all around, new rear rotors, new BMC (200sx Turbo 15/16 due to 180sx front brake setup). Starter is under 2 years old. Currently automatic, but I can include 5sp conversion parts for an extra $350 (read below). I also have a Felpro engine gasket rebuild kit which has a shitload of gaskets (including headgasket and valve seals).
    Bad
    Just started rod knocking. Cranks and runs just fine, but rod knock developed just today. Did compression test today, and got 160-162 on all 4, cranked it up immediately after, and rod knock was happening. Will need a timing chain job (have OEM parts to do a rebuild, which will be included). Will need a driver's side fender, which a spare will also be included. Will also need an alignment and new set of FRONT tires (or at least a new front passenger side tire).
    PRICE: $1,000 OR $1,350 w/ 5sp parts (almost complete, ONLY missing a clutch kit + flywheel + flywheel bolts, and lower 5sp harness - includes pedal, hardlines, master/slave cylinders, 91k mile transmission, driveshaft, shift knob, lower and upper shifter boots, brand new Nissan engine-to-transmission bolts, and 5sp sandwich plate that goes in between the engine and tranny)
    CONTACT METHOD:
    AIM: kraziblkboi / neejae @ gmail.com / 678-697-3853 Nick
    - 2011 BMW 535i M-Sport - BMS Stage 1
    - 2003 TL-S Totalled
    - 2004 TSX - A-Spec wheels
    - 1991 S13 RB25DET S2 - sold, and missed
    i got dibs!
    do you have the interior pieces you stripped out?
    Hoschton
    damn, you dont see any of these lookin this clean nowadays.
    bump for a clean ride
    Quote Originally Posted by Driftk1d350z
    i got dibs!
    lol Cant really call dibs on a car man But, its not stripped badly, its just the rear seats taken out, and the cardboard taken out around the hatch area. Right now the panel that goes over the driver side seat belt is off, and that's only because I did the manual seatbelt conversion on the driver's side.
    I'll take some more pics when I get a chance.
    San antonio 210
    that sux that its auto.. but GL on sale
    Senior Member babowc's Avatar
    Manual stuff are being included with the car
    you'll probably have to pull that motor anyways..
    while you're on it, get yourself a new tranny and get to town on the 5spd swap.
    its not that hard, just time consuming.
    plenty of writeups all over the net as well
    gl with the sell Nick!
    Thanks man.
    All pm's have been replied to.
    Henry Co.
    i used to hate against Pignoses soley for the fact that they are SOHC, but then after I realized it was only a 10hp difference I didnt mind so much. Besides, very rarely do KA's stay in a 240 engine bay
    SOLD!
    damn that was fast. how did those teins treat you?
    Quote Originally Posted by BenefitX
    Very good, I would get them again, but now days you can find better for a little more.
    I still have the 5sp stuff, but I'll make another thread for the stuff + pics.
