Results 1 to 18 of 18
Thread: stock h22a4 with turbo???
    Default stock h22a4 with turbo???
    wondering how good will my prelude be if i was to boost my car. i have a 97 prelude sh, bone stock, n if i was to turbo my car @3-5 psi, then how many hp will i gain? is it worth it, or wat???
    96 black prelude si SOLD
    97 silver prelude sh traded
    98 honda hatch B18c1 done
    02 s2000 dd
    do 8psi with a tune you should see about 280whp, 5 might get 220-230ish!
    About to approach beast mode
    who does 3psi??
    im talkin about a completely stock motor with nothing in it!!!!!!! i just want to go straight turbo. n i want to know how safe is it? will my engine last, or wat??
    02 s2000 dd
    low boost IMO 5-7, but i'd do prolly 8psi w/ a tune
    so how safe will it be running @ 8 psi? how long will my motor last?
    02 s2000 dd
    Woodstock
    5-7 on stock motor...
    Val RIP
    my only rule in life
    H22 kyx's Avatar
    there was this guy in pp.com that runned 9psi on a custum turbo and had around 330whp...(turbo'd the car at 130k, too, bone stock engine.)
    Place Signature Here.
    Woodstock
    Quote Originally Posted by kyx
    how long has he had the kit on there?
    Val RIP
    h series
    norcross
    12psi ftw. its been done just not very long. i think 8 would be perfect just dont get to greedy
    you can figure 7-13hp per pound of boost added to the stock hp wheel output...10hp/pound is a good estimate. therefore, 3-5psi=30-50hp over stock. 7-8psi tuned should be ok and fun daily driver.
    To 942JZGTE 93H22ACX's Avatar
    there's been a few people running 8-10psi that is making 300-330whp on completely stock h22.
    H22 pistons dont like the excessive peak cylinder pressure. Keep the timing very convservative and it should be fine.
    Low boost should be 6-8psi...under that is really a waste and nitrous would be your best bet.
    94 Supra= 500rwhp
    superduper LLLLLLLLL
    ^^ what he said!
    Senior Member BlkCD5's Avatar
    High compression stock motors + boost =
    Quote Originally Posted by BlkCD5
    not necessairly.... the reason why the h22's dont handle boost so well is because the ringlands are set higher on the pistons. This means its easier to break with excessive cylinder pressure....
    Type R and GSR do fine and are not as susecptible to piston failure as h-series...although there are a few Hseries that have been known to make some decent power stock too.
    94 Supra= 500rwhp
    damn, i should of rephrased that, I meant high boost. We all know the H22 rings suck, but i heard a stock H22 can hold 15 psi at the most, not for long though.
    IA Member Kevin01SH's Avatar
    Might i suggest the Jackson Racing Supercharger? All around its better than a turbo on a stock H22, especially with you having an SH like me theres only so much power you can put to the wheels before the ATTS unit doesnt work anymore. The JRSC runs on 7psi, no internals needed, comes with a warranty and can pass an emissions test with no problem. Bolts are not required, but as with any engine they will help.
    Only real downside to it is the type of engine management it has, most people will tell you to get something else. Again since you have the SH you're gonna want a piggyback system so you dont lose your ATTS.
    2001 Prelude Type SH
    so the atts light will cut on if i was to boost it? or wat
    02 s2000 dd
