Results 1 to 15 of 15
Thread: what is zero offset ? flush w/rims??
    Banned lsxtreme's Avatar
    Default what is zero offset ? flush w/rims??
    is this offset flush with rims? or flush with the wheel well..
    pictures by any chance..? LMK ASAP..
    wtf? what are you askin? 0 offset is how far away the face of the wheel is from the center on the rim. Basicly, dead center on the rim.
    I can't explain it. Someone else chime in.
    The Other White Meat gijoe0720's Avatar
    Trion, Ga
    hmm thanks for the fawken info .. kind gives me an idea now.. anymoresuggestions.. pictures.
    Trion, Ga
    0 offset the lugs would be in the center of the wheel. If you had an 8 inch wide wheel and the offset was 0 then the lugs would be 4 inches in.
    I am Montage
    Augusta, GA
    depends on what kind of car its on. flush to a civic is like ...15x7.5 w/ +38 offset? not 100% on it, but my 240 is flush w/ F16x7 and R16x8 w/ +20 offset. like hachidori said, its how far off the center of the rim in cm's that the lugs screw on, +40 is 40cm towards outside of rim where it bolts up from the center. hope that helped
    Trion, Ga
    Quote Originally Posted by blue_5g_zc
    depends on what kind of car its on. flush to a civic is like ...15x7.5 w/ +38 offset? not 100% on it, but my 240 is flush w/ F16x7 and R16x8 w/ +20 offset. like hachidori said, its how far off the center of the rim in cm's that the lugs screw on, hence offset: 0 is neither + or - , aka dead center, meaning itll bolt up 4" in if it were a 8" rim in width. +40 is 40cm towards outside of rim where it bolts up from the center. hope that helped
    repost
    I am Montage
    Augusta, GA
    tushay, somehow i got caught in my ramble and forgot. good call
    Here and there Hulud's Avatar
    Omnipresent
    tushay
    wtf?
    do you mean touche?
    Val for President
    I am Montage
    Augusta, GA
    no, i mean touché but thanks for trying
    wtf?
    do you mean touche?
    Wheel Definitions:::
    Here is a pic, since this is the pics section:
    the land of race car ya-yas.
    http://www.rims-n-tires.com/rt_specs.jsp
    here. it's a pretty good wheel size/offset calc. you can use to get a better idea. basically, 0 offset is the middle of the wheel. anything to the inside of 0 will be negative. anything outside of 0 will be a + offset.
    Try millimeters (mm) 40cm is nearly 16 inches
    all this time ive heard of offset this and offset that and never really understood what offset is...and now w/ this one simple statment is all so clear
    reps
    I am Montage
    Augusta, GA
    haha, ur right on, the only thing 16 inches around here is the huge donkey doogin of mine that keeps tripping me up
