Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 201 to 240 of 393
Thread: E36+Nelson combine to form the (Official) Epic douchebag thread. WARNING!
  1. #201
    Jan 2010
    We can do business
    One thing I have learned about IA. No matter how right you are, and what argument you bring, you're still a moron. It's like highschool. This is a popularity contest.
  2. #202
    Quote Originally Posted by nelson9995 View Post
    Unfortunately, you just surf around getting called a moron without being right or having good arguements.
  3. #203
    HollaHollaHolla carguy07's Avatar
    Columbus
    Please learn to multi-quote. Two post in a row is not a big deal, four is just pointless. Mentioning that you are in your phone (if that is the case) doesn't help.
    That is all.
    1993 240SX single cam
  4. #204
    Let me go ahead and end this for you, faggot. A 500whp NA LSx motor in a basic suspension setup fox body will walk both the 600whp RB26 car and SR20.
    That's all you need to know.
    NA LSx > 100hp more boosted 4/6 cylinder.
  5. #205
    Johns Creek
    JESUS.
    do you guys not read what I write?
    I said same conditions
    My point is that it is almost completely impossible to have the same conditions for both cars. There will always be more variables than just maximum hp and tq figures.
  6. #206
    Johns Creek
    David you seem to be pretty educated.
    Please explain to these people how a powerband/boost lag works. and how a 600whp sr20 is not the same as a 600whp rb26
    Because according to sinfix and his follower, boost lag is non existent, so is a powerband.
    Sinfix argument states that a sr20 will make the same power as a rb26/25 or ka24 with the same amount of work (which all have pretty much the same redline (except ka)
    That's like me saying a fully built b16 making 600whp is the same as your mustang making 600whp and both motors take the same stress at 600whp
    I will start with the assumption that we are starting from a dig.
    Boost lag should be neligible as you can pre-spool and load up a turbo.
    Different engine make different tq curves and have different values for volumetic efficiency. In this arguement over which engine is better, what you should be discussing is volumetric efficiency. Any other comparisons are useless as arguing points.
  7. #207
    Jan 2010
    We can do business
    THANKS FOR PROVING MY POINT YOU FUCKING DICKHEAD
    a 4 cylinder 2.0 sr20 WILL NOT outrun a 6 cylinder rb26 motor assuming both have the same amount of work/money in it
    GOD DAMN you fuckers keep proving my point and not seeing it
  8. #208
    a 4 cylinder 2.0 sr20 WILL NOT outrun a 6 cylinder 2.6 motor assuming both have the same amount of work/money in it
    What the fuck did you just get from me letting you in on a well known secret that fox body + lsx = owning everything?
    God damn.
  9. #209
    Jan 2010
    We can do business
    Quote Originally Posted by David88vert View Post
    Thank you
    It is known fact that the rb25/26 and ka24 all have a better powercurve than the sr20 and make more power per psi assuming everything is equal and proportional.
    Doesn't this prove my point?
    Why can't a sr20 make more than 450whp on pump gas?
    Why can the other 3 motors break 500whp with a stock head and pump gas?
  10. #210
    Jan 2010
    We can do business
    God damn.
    You proved my point
    why will it win with 100whp less NA?
    BECAUSE IT HAS A WAYY BETTER POWERBAND AND NO BOOSTLAG you prick
    case closed
  11. #211
    Jan 2010
    We can do business
    So boostlag doesn't matter when you shift?
    A 800whp rb26 will walk away from a 800whp sr20 on every shift, and last twice as long ... assuming both start from a roll, have no traction issues, or at least with the same driver
  12. #212
    The only logical explanation I have for your lack of logical thinking is female genitalia.
  13. #213
    Jan 2010
    We can do business
    LMAO. I beat those all the time
    you made yourself prove my point.
    Thank you.
    really
    I was starting to get frustrated
  14. #214
    Johns Creek
    Thank you
    You proved my point
    case closed
    I don't think that you are understanding what I am saying.
    Volumetric efficiency is not "powercurve".
    It is possible for a 4 cyl to have better VE than a 6 cyl. I am not familiar with specific Nissan engines VE to state conclusions without looking them up.
    Torque curve is not "powercurve", as power is not the same as torque. Torque is a defined measurement of pound-foot (not foot-pound) .
    Power is how much work can be performed in a specific time period.
  15. #215
    Jan 2010
    We can do business
    or please explain to me why you believe that lsx will walk any turbo 4/6 cylinder with 100+whp??
    or is it just because the lsx is badass lol
  16. #216
    Jan 2010
    We can do business
    I am going to use actual numbers wo we understand each other.
    If one motor (2.4/ starts building boost at 3k) makes 480whp 470wtq (built block stock head) and redlines at 7.5k
    The other (2.0/ start buildng boost at 4k) makes 480 whp 390wtq (fully built on race gas) and redlines at 8k
    Which one you believe has a better powerband?
    Which one you believe will have more boost lag?
    Which one would you chose to make 700whp?
  17. #217
    Johns Creek
    No. Boostlag will only matter if you don't know how to drive. You can easily minimize boost lag with an auto running a custom converter or by powershifting a stick. For drag, you would generally run a built automatic.
    Your scenarios are attempting to compare two engine by complete packages of car and driver. This is futile and rediculous. If you want to compare two motors you have to look at the VE of the engines.
  18. #218
    Jan 2010
    We can do business
    You can also make a fat girl look skinny with a tummy tuck
    Jan 2010
    We can do business
    Which one will be more reliable at 700 whp?
  20. #220
    You should go back to trying to get people to drop your name at the club rather than engaging in conversations concerning automobiles and internal combustions engines.
  21. #221
    Jan 2010
    We can do business
    please get out. someone tell him he proved himself wrong with the lsx rb26 comment lol
  22. #222
    Johns Creek
    In this scenario that you present, either motor could be used and in the same chassis, could do the same times. Just comparing maximum hp and tq figures mean nothing. You need to know the graph plot of the engine across the rpm range.
    I'm not sure that you understand how horsepower and toque are measured an d how you utilize those measurement to plan usage of power output in a meaningful way.
  23. #223
    Earth
    I like Dragons.
  24. #224
    Jan 2010
    We can do business
    the 2.4 makes is already making more power at 3k, 4k, 5k, 6k, 7k, and also starts spooling 1k earlier
    how about now?
  25. #225
    Earth
    Jan 2010
    We can do business
    I believe you guys are just trolling me now. lets be real
  27. #227
    Earth
  28. #228
    Jan 2010
    We can do business
    God I wish sinfix still had his car.
  29. #229
    Johns Creek
    That's easy. If the engine has enough block and component strength, and has an experienced and competent builder, with a tuner who understands how to tune for volumetric efficiency, then the motor should live without issue. In other words , both should be reliable as long as those conditions are met.
    You can't just say that one motor is always better than another because it is bigger. I see 363ci motors easily outrun 440ci motors plenty, and last longer.
  30. #230
    Earth
    I'm going to start a thread letting all the b16s guy know that they have hope.
    Why upgrade to a GSR?
  31. #231
    Jan 2010
    We can do business
    THAT IS NOT WHAT IM SAYING
    the sr is an aluminum block (prone to warp)
    ka24 is iron
  32. #232
    Jan 2010
    We can do business
    so which one would you say has a better powerband?
    less boostlag?
    and which one would you chose to make 700whp.
    please answer my 3? so I can get out this thread
  33. #233
    Jan 2010
    We can do business
    So a 1000whp b16 is just as reliable as a 1000whp ls7 given they are both tuned correctly?
  34. #234
    Johns Creek
    how about now?
    Still too many variables unanswered. You are simply looking for someone to say that "bigger is always better", rather than try to understand the truth.
  35. #235
    lmfao. This is sadly hilarious.
  36. #236
    Jan 2010
    We can do business
    THE KA24 has been proven to make more power with less so have the other 2 motors
    I'm not saying bigger is better. In the 4 motors I have stated yes it is better
    If the sr20 guys are happy at 2.0 why do they all go 2.1/2.2/2.3 when they sleeve?
    If size wasn't a factor and if the turbo is the replacement for the displacement why not leave it 2.0 and run an extra psi or 2 to make up for it?
    have a nice night guys
  37. #237
    Johns Creek
    ka24 is iron
    Aluminum blocks are used all the time in racing. They are less prone to hot spots and can be easily sleeved. Heat is the greatest enemy of engines and aluminum is better until you get to extremely high hp cars.
  38. #238
    Jan 2010
    We can do business
    My problem here is that everything powerwise that I have stated has been proven.
    It has been proven that a ka24 can make 500whp pump gas stock head
    It has been proven a 500whp sr20 can't be seen w/o a built head
    Also has been proven that a ka24 will make power down lower along with extra tq that the sr20 can't find
    this closes my argument
    do you see why I am arguing now?
  39. #239
    Like Mazworx's 1000hp SR20 that is stock stroke and only .5mm over standard for the bore? Do you realize how little .5mm is as far as power is concerned?
  40. #240
    Jan 2010
    We can do business
    LOL
    There is a 1000whp KA on a stock block (not pistons/rods) and crank
    go to ka-t.org and educated yourself
    GTFO
Tags for this Thread
