Results 1 to 15 of 15
Thread: gsr-t tuning question
    rollin 91 da egpower904's Avatar
    Dallas, GA
    Default gsr-t tuning question
    hey i have a da integra with a '95 gsr swap and a .57 trim t3t4. many mods done to car, has a cracked manifold that i am going to swap with a blox cast log. what kind of reliable hp/tq numbers are typical assuming i come get yall to dyno tune it?
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
    Stock motor?
    If so reliably not much over 260-270whp 7-10psi. You can make more but on a stock block and depending on mileage you may want to keep the boost and power down to safer levels.
    What do you have to tune with? Is it obd1 or obd0? What size injectors? What ecu?
    Dallas, GA
    its stock inside. ecu has been chipped and socketed (donno what software though) was gonna have main check that out, dsm 440's, its got a p28 so im guessing obd1? also has a walboro 255 lph fuel pump, str fuel rail.
    DA SQUAD MEMBER #70
    Dallas, GA
    oh and prev. owner claims 75k on the swap. odo shows 229k on the car.
    DA SQUAD MEMBER #70
    near stock reliability...250-275whp. 300 isn't unheard of, but reliability starts becoming questionable when you push the motor well past 100whp over stock.
    def want to get the crack fixed first before tuning.
    Dallas, GA
    Quote Originally Posted by scttydb411 View Post
    since i have a new manifold coming in (http://jhpusa.com/store/pc/viewPrd.a...&idproduct=612) couldnt i pull my old one and possibly get it welded back up and sold? heres a pic. it has a crack where runners #2 and #3 meets the block flange and a crack where all 4 runners meet at the turbo flange.
    DA SQUAD MEMBER #70
    Since you are going from that to a log you will probably have to rework, downpipe, oil lines etc... and noone is going to buy that manifold, they are drunk.
    Dallas, GA
    yeah i figured thats what i was looking at since the turbo will get moved up and closer to the block. the downpipe probably wont clear. but about the oil lines seem like they might work but idk for sure. when i get the mani if i have any doubts of doing it myself ill see about getting it up to you guys. thanks
    DA SQUAD MEMBER #70
    no prob, just throw the old one in the trash so noone else has the same problem!!
    Dallas, GA
    is xs-power shitty stuff cause thats what it is, and so is my WG. i want a tial
    DA SQUAD MEMBER #70
    Dallas, GA
    sooo.. christmas came and went. heres my result ill be trying to get my car up there as soon as i get the rest of my $....oh and will this use just an oem honda gasket or something, cause it didnt come with one??
    DA SQUAD MEMBER #70
    stock exhaust gasket will be fine. grounding marks is where they took off the sharp edges of the casting.
    don't need a gasket on the wastegate if you don't have one...you do need to make sure you have the fire ring installed.
    Dallas, GA
    thanks scotty, i hope there is clearance for the turbo though, dont want to have to notch the block
    DA SQUAD MEMBER #70
    IA's bass guy
    Nov 2009
    paulding
    Quote Originally Posted by egpower904 View Post
    lets just hope this is all thats wrong with it,
    99 tahoe, build in progress
    Dallas, GA
    Quote Originally Posted by imprtguy_94 View Post
    this, new bov, and a tune. probly should get the new plugs/wires too. and i need 4 tires, and paint. and a new left tail. and a windshield.....
    DA SQUAD MEMBER #70
