- Knock Sensor issue
- Rep Power
- 0
Knock Sensor issue
I've got a 96 civic with a D16z6 vtec swap, it is running off of a p72 ecu from a gsr and vtec will not work, says i gotta bad knock sensor but the z6 does not have a knock sensor, is there any way to bypass that so it will allow vtec to run?
you should really be using a P28 man.
jump obd2 to obd1 and use p28
- Rep Power
- 0
Alright sounds good, thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
