- tach wiring help please
at the dizzy plug, there should be a SOLID blue wire (this is your tach signal).. follow it all through the engine harness through all the plugs and to the cluster and fix any breaks you see. IF it still does not work after fixing all breaks (if any) replace your cluster or replace your ignition coil inside the dizzy
- You may not post replies
- You may not edit your posts
Forum Rules
