anyone know where i ca find a good DIY or guide to install an Autometer Airfuel gauge for a 99 civic ex
what series is the guage?
2001 Honda Prelude Base model
http://www.cardomain.com/id/twkg2001
Originally Posted by Prince NISMO
all auto meter gauges are the same i think justin
hope this can work for yeah
http://www.prostreetonline.com/pso/p...sp?articleid=3
i just figured the cobalt had a wire for illumination along w/ everything lol.Originally Posted by flysi00
i got the autometer sport comp...appreciate the posts
the link doesn't help much..any other links?
actually thats a pretty acurate link. its all basic wiring red (+), black (-)...run the power n ground like you would. then there should be a purple wire which you can either connect to the signal wire for your o2 sensor or you could just extend the wire to your o2 sensor wire in the engine bay.
Yep i was about to say that that kind of gauge do u haveOriginally Posted by twkg
i had a couple of people tell me to stay away from the o2 sensor
then go buy a EGT gauge my friend or put your a/f wire to your ecu wire that reads the 02 sensor but even then its going to read the same thing so if u dont want to hook it up to the 02 then get a EGT gauge
i'll try the ecu
either way its gunna take forever to figure out which is the signal wire to the o2
gotta do it somehow
02 sensor its going to read the same thing cuz if u think about it the wire from the 02 going to the ECU so its going to read the same air/fuel
so there is no good or right way to hook up the airfuel?
just hook it up to the o2 sensor.....its not dangerous or anything...thats what mines hooked up to....whoever told you to stay away from the o2 sensor might not know what gauge your putting in or doesn't know what they are doing
i know you love my swagger
OG Black Delegation member
RIP My Homie Elliot Sloan
I've always hooked the up the purple wire to the O2 signal wire. Use a T-tap or the like. Find where the O2 sensor signal wire plugs into the wiring harness and tap in there. No need to be right by sensor.
^^^ foreal...try doing it the right way first. i hooked mine directly to the o2 only because i couldnt find another way and got tired of waiting to install. it worked fine but still looked half assed.
cuz u need to learn how to do wiring justinOriginally Posted by twkg
so o2 sensor huh?
it sounds like a yes
FUN FUN FUN
MI-4
O2 SENSOR. why run to the ecu? just get a multimeter to figure out wich of the 3 or 4 wires is signal, green is signal on some hondas. if you know how to do clean install with wires, it will look just fine to all the 2 inch high people walkin under your car inspecting the wiring. good luck, its an easy install. wire it in above the 02 harness, or into the top part of the harness. will save ya trouble if you have to yank the 02 sensor. 02 sensors are fairly usless, so have fun with the anoying lights.lol..
hmm damn still doing some more researfch
