Results 1 to 17 of 17
Thread: high idle problem
    Default high idle problem
    I was driving up 75 North and suddenly my car felt liked something slipped out of place. I pressed down the clutch to the floor, and the idle was stuck at 3000 rpms. The car still shifts into gear and it engages properly, but at a higher rpm now. No check engine light came on and it was not overheating. I looked for leaks of oil, but found nothing. What could be the problem?
    WEST_SIDE
    check the idle adj. screw. i think yoiu jsut got a MaJOR vaccum leak, check all vac hoes
    -Ernie
    how do i check the hoses and adjustment screw?
    lawrenceville
    i wouldnt mess with the adjustment screw yet. id check all ur options first bc a lot of those are set from the factory
    WEST_SIDE
    Quote Originally Posted by 3kgtdrvr
    what i meant was to check if its even there. i seen ALOT of adjus, screws fall off . dont ask me how they just have .lol
    -Ernie
    your moms house
    i would take it to someone who knows what they were doing....
    no offense but if you cant/dont know how to check for a vacuum leak , you shouldnt be working on cars
    FUCK B&D COMMUNICATIONS!
    lawrenceville
    ^haha. i didnt wanna say it, but yeah, he definately has a point.
    None taken. I just want the problem fixed by midnight.
    Alright, I checked all the vacuum lines coming from the intake manifold and all were firmly connected. I also took a look at all the other vacuum lines and they were also firmly connected. I tightened the gas cap and the idling went down to about 2000rpms. After driving around for a while, the idle dropped to 1000rpms, but now the idle is uneven. I keeps going up and down slightly. The idle is tremendously lower now, which is good, but the unevenness of it has me wondering. Anybody have any ideas?
    Today the accelerator is sticking in place when it is not depressed. I have top give a it a light tap to get it loose enough to move the car.
    IA Member souldigger's Avatar
    Tucker, GA
    Check the IACV - Idle air control valve. Its under the throttle body on dc-2's. n Might have backed itself loose. This happened to me on my 94. It was a dry rotted o-ring on the IACV.
    -Jason
    too many projects
    Greensboro, NC
    also if the pedal is sticking clean the butterfly in the tb that it gunked up and cause the butterfly to stay open with out returning to close. But if the idle is just up and done will sitting at a stop light or some thing like that it is your iacv. Is that the org tb on there and has it ever been taken off the car? If that gasket didnt seal right around the tb it will cause that kind of issue. A way to check that would be to get a can of carb cleaner while it is runnign and spray around the tb were it meets the im ( intake manifold) if the idles bogs out or increases you could have a leak ( meaning a bad gasket) at the tb.
    11 camry se
    99 cbr 900rr on n2o
    97 accord h22 on 25psi
    06 scion xb
    01 expedition
    WEST_SIDE
    Quote Originally Posted by souldigger
    -Jason
    btw, FITV not IAC
    -Ernie
    Tucker, GA
    Quote Originally Posted by SLow_POke
    btw, FITV not IAC
    -Ernie
    ooops, yeah I always get those backwards. i meant the fitv.
    -Jason
    I will check the tb gasket tomorrow, but I must know what the FITV is and where it is located.
    Super Dave Z U L8R's Avatar
    Roswell
    this is like the third post i've seen already with idle problems with a probable cause of DIRT/FILTH/CRAP/SHIT/DEBRIS/CACA/POOPOO ETC in the fuel delivery and induction system of a honda.
    DUN DUN DUN DUN!!! PRVENTATIVE MAINTENENCE!!! changing air filter every 12,000 miles WHOAH!!!!!!
    Air filter $12
    Fuel system cleaner $5
    Carb & choke cleaner $3
    Doing recommended maintenence on your car = a lot cheaper and easier than fixing the problem AFTERRRRRRRRR you have the problem.
    Roswell
    sorry for venting on YOU! persay, but take better care of your cars
