- Civic Not Starting Up!!
- Rep Power
- 0
So,
Here's the dilly. I got a 1993 Honda Civic DX 2 dr. It died out on me about a week or 2 ago while at a red light. Just shut off. Bastard. Anyways, it cranks and rotates but wont start up or/fire up. Iniitally I thought it was the main relay cause they always f&ck up on civics in hot weather. But it is not the main relay. I tested it. Also i smel gas, so i am sure the civic is gettin gas to the motor. But we all know it requires 3 things. Spark, Air and Fuel. I also checked to see if the timing belt was turning , and it was. So timing belt is not hte problem. Battery is good. All fuses check out okay. i dont think it would be the ECU because i know ppl that could start up the car without the ecu. so im 60% sure the ecu is not the problem. Any ideas, suggestions. or what? Let me know. Thanks!!!
- You may not post replies
- You may not edit your posts
Forum Rules
