Thread: Battery corrosion help
    Projects
    Default Battery corrosion help
    My wides car for the past 5 years has had bad battery corrosion on her +cable end.
    I have cleaned and replaced the terminal 3 times. I'm tired of having this issue and it causing problems for her car. What keeps causing it to return ?
    Ive used coke and tried baking soda and the foam corrosion spray from autoparts store.
    I get it clean enough to eat off of but within a week it starts to build back up. At times it look like s giant snow ball. Please help me out....
    Stang Mod slostang's Avatar
    Southside
    its in the cable itself. Id go ahead and replace both cables and clean the battery terminals and connections at the starter / fuse block very well with the corrosion cleaner they have at parts stores. Once you do that put a little Vaseline on the battery terminals for added protection.
